1956 engine suffix code cf
Old Jul 1, 2022 | 10:45 AM
kenba's Avatar
kenba
From: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
Default 1956 engine suffix code cf
Off topic a bit but I have a 56 Chevy35000 restored truck & cant see the casting # pad is stamped F0528CF. Is that a code for 265 or 283? looked on line & cant find a CF code.Heads do NOT have staggered valve cover holes. THANKS KEN
Old Jul 1, 2022 | 01:20 PM
Rumblegutz's Avatar
Rumblegutz
There are CF suffix 283's listed from 1958 thru 1961. All 230hp 4 bbl manual trans in passenger cars. Then again in 1964 but 195hp 2bbl 4 speed Nova
Old Jul 1, 2022 | 01:42 PM
kenba's Avatar
kenba
THANKS
This motor has front motor mounts. Thought only 55,56 &57 had front mounts. Cant see the casting # because they set the cab over the back part of the engine. I want to put 56 2-4 intake & valve covers on it.
Old Jul 1, 2022 | 03:05 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Originally Posted by kenba
THANKS
Most SBCs until sometime toward the end of production had the drilled/tapped bosses for front mounts. Those threaded holes were often used for accessory mounting after they were no longer needed for engine support.
To 1956 engine suffix code cf
