[C2] Timing issue with 350 engine
The distributor shaft turns clockwise with the engine running so to advance the spark the distributor housing must be turned counterclockwise so the triggering mechanism, points or electronic module, operate sooner. Does that make sense? I have a tendency to over state things.
Tom
Tom
http://www.stl-vettes.com/65Vette/co...istinstall.pdf
But, is that what you need? If the engine wants the spark to happen when the timing mark is, say, 10* ATDC, then moving the distributor isn't going to make the engine like timing at 10* BTDC. I'd wonder if the timing mark is correct or the balance has rotated. Was everything fine and checked out before you replaced the distributor?
A photo of the front of the balancer may reveal deteriorated rubber. You can also mechanically check by bringing your #1 to top dead center using a piston stop and checking the balancer mark to the tab.
Did you try using a multimeter as in step 7 of lars paper?
Here's how I'm thinking about this:
--The timing light flashes when the spark happens (unless you're using a dial-back light)
--The flash illuminates the balancer at that point, which allows you to see when the spark occurs relative to when the #1 piston is at TDC (assuming the timing light is on the #1 wire), by looking at the balancer index mark relative to the index tab affixed to the timing cover.
--How the distributor is oriented changes when the spark happens, which you see by the change in viewed position of the timing mark relative to the index tab
--Your engine doesn't want to run when the spark occurs before #1 piston is at TDC, but appears to like to run with the spark happening well after #1 piston is past TDC.
--It's unlikely the engine really prefers a spark well after #1 passes TDC
--While moving or resetting the distributor will change when the spark happens, it won't make the car suddenly like a spark before TDC when it didn't like it before.
--So, I conclude that there is something likely wrong with the balancer (or possibly cam phasing, but that's much less likely, in my view)
I think you should definitely get #1 to TDC and see where the timing mark lines up. That should be a pretty easy test.
I know, another dumb question. LOL
