64 Corvette
Old Oct 1, 2022 | 06:59 PM
Fraz's Avatar
Fraz
7th Gear
Default 64 Corvette
I have a 64 Corvette that had a vibration in the left rear after 55 mph. I installed new Diamond Back tires, computer balance and new Garbrlal Ultra Shocks with no change.
All U Joints seam solid and nothing is loose that i can find.
Any Ideas would be appreciated
Mike
Old Oct 1, 2022 | 07:01 PM
Powershift's Avatar
Powershift
Wheel bearings.
Larry
Old Oct 1, 2022 | 07:02 PM
leif.anderson93's Avatar
leif.anderson93
Originally Posted by Powershift
Wheel bearings.
Larry
You might, also, check your trailing arm shims...make sure they're in place.
Old Oct 1, 2022 | 07:04 PM
Fraz's Avatar
Fraz
7th Gear
Default 64 Corvette
They are making no noise but that sounds like a good idea although i have never a wheel bearing go out without noise.
Fraz
Old Oct 1, 2022 | 07:22 PM
Fraz's Avatar
Fraz
7th Gear
Thank you. They seem to have all the shims. I was thinking trailing arm but with new shocks it don't think its would be them.
Old Oct 1, 2022 | 07:45 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Did the car have the vibration when you bought it, or it WAS ok and then started having the problem? If it used to be OK, did you change anything or have anything else going on about the time you first noticed it? Did it come on gradually, and get more intense over time, or nothing one day and it's there the next?
Old Oct 1, 2022 | 07:51 PM
Fraz's Avatar
Fraz
7th Gear
Not sure if it had it al along time or not. Never has seen a lot of highway miles in the 5 years I've had it. it is very much babyed
Old Oct 2, 2022 | 05:43 AM
LeeS's Avatar
LeeS
You need to make sure you had a Road Force Balance done with the new tires.. Could be as simple as that.
Old Oct 2, 2022 | 07:44 AM
Bowtyeguy's Avatar
Bowtyeguy
Switch the tire from left to right to make sure its not in tire. Do the easiet first.
Old Oct 2, 2022 | 07:39 PM
Fraz's Avatar
Fraz
7th Gear
I have not heard of Road Force Balance. What is that?
Fraz's Avatar
Fraz
7th Gear
Tires are new and it the same as before..
Old Oct 2, 2022 | 08:26 PM
Railroadman
Rather than just spinning the tire/wheel, road force balancers have a roller which exerts pressure on the tire as it is tested, to simulate the weight of the car in actual conditions. Not all shops have them but it's generally accepted that's a more accurate measurement than the old way.
Old Oct 2, 2022 | 08:30 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
the old way would be to bubble balance
Old Oct 2, 2022 | 09:04 PM
Railroadman
You are right, and I have been there done that many times back when gas stations did repairs. I just figured it was easier to say "old way" than "in between way" or "not quite old way"
To 64 Corvette
