Defrost cable differences?
Old Nov 14, 2022 | 06:47 AM
Tuco888's Avatar
Tuco888
Default Defrost cable differences?
I want to put a new heater control cables in my 63 while the dash is out. The old ones are too hard to operate and put too much force on the dash. I can find the heater control cable with the switch but the only defrost cables I can find are for cars with ac. Anyone know what’s different about them from the ones for cars without ac?
Old Nov 14, 2022 | 09:13 AM
vettsplit 63's Avatar
vettsplit 63
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
I went through this when restoring my 63. As I remember, the blower motor wont work unless you have the one exactly like was in it. The a/c ones have more terminals, and will not work. Supposedly the ones you get from CC will work if you add another hot wire to your fuse box coming from their repro cable. . I didnt want to do that. I elected to buy a nice used one from JT Piper.
Old Nov 14, 2022 | 09:31 AM
Tuco888's Avatar
Tuco888
That’s for the heater control cable/switch. I’m talking about the defrost cable. (Right side cable.) There’s no switch just a cable that goes to the diverter. I don’t understand why they would be any different for ac cars versus non ac.
Old Nov 14, 2022 | 11:46 AM
vettsplit 63
St. Jude Donor '12
Sorry, i guess RIF Igot focused on the heater control cable.
Old Nov 14, 2022 | 12:53 PM
silver837's Avatar
silver837
I would try to clean and lubricate the original cables .
Old Nov 15, 2022 | 07:59 AM
TokyoMark's Avatar
TokyoMark
Retired
Joe. The defrost cable (the one next to the passenger) is about impossible to find a new one. You can find an AC defrost cable but not a non-AC cable. The difference between the two is the length. The non-AC cable is about 3 1/2 inches LONGER than the AC cable. I tried an AC cable and could not get it to fit the way it was supposed to run. The routing (starting from the heater box end under the defrost duct) is toward the passenger then under and behind then over the heater box and then into the dash. The AC cable is not long enough to do this.
I snapped my cable outer casing and had to do what I could to repair it. It works but is very tough to pull in and out. I have moved on to other things but in my quest for a cable I found a forum member that is making cables for a company that should be available soon. If you send me a PM I will track down the company and respond back. Or if he see's your post he may respond. Good luck.
Old Nov 15, 2022 | 09:12 AM
Tuco888's Avatar
Tuco888
Thanks Mark. I found this one and ordered it. We’ll see how it fits. https://www.corvettepacifica.com/pro...ing-usa-63-67/
Old Nov 15, 2022 | 09:22 AM
TokyoMark's Avatar
TokyoMark
Retired
Thanks Joe. I may order that myself. Cheers
Mark
Old Nov 16, 2022 | 06:14 AM
Tuco888's Avatar
Tuco888
Mark
I just got a note from them saying they are currently back ordered. Surprise surprise! Said they should get them in 3-5 weeks.
To Defrost cable differences?
