engine from Ecklers
Old Nov 14, 2022 | 01:38 PM
xsray's Avatar
xsray
Default engine from Ecklers
i'm looking for an alternative to rebuilding my original L79, does anybody have experience with this engine from ecklers?
https://www.ecklerscorvette.com/chev...-340098-1.html
TY
Old Nov 14, 2022 | 01:50 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
For the work involved of removing and installing and storage or scrap it the original, I personally would have my original rebuilt/restored. Their choice of camshaft is very limited, no description of pistons.
it also costs less to rebuild and restore the original 350 hp than to install a 250-300 hp.
I like my L79 as a genuine L79 with its hp, rpms, idle lump, and exhaust notes,
your money, your choices.
Don
Old Nov 14, 2022 | 02:03 PM
Audiophobe's Avatar
Audiophobe
No brainer (to me).
Old Nov 14, 2022 | 02:20 PM
xsray's Avatar
xsray
it;s just that my mechanic quoted be 10k for a rebuild.
Old Nov 14, 2022 | 02:29 PM
Vega$Vette's Avatar
Vega$Vette
Yep Cheaper to do a crate with warranty than rebuilding.
I would personally not buy from Ecklers
I would go with something like this for about $1000 less and a 50,000 mile warranty
https://blueprintengines.com/product...ads-roller-cam
Old Nov 14, 2022 | 02:30 PM
Audiophobe's Avatar
Audiophobe
Does $10k sound high though?
Old Nov 14, 2022 | 02:37 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Depends how much extra work his mechanic is going to do
Old Nov 14, 2022 | 02:39 PM
xsray's Avatar
xsray
thanks, that's what i'm looking for. will my intake and exhaust manifolds fit with this?
Old Nov 14, 2022 | 02:45 PM
Nowhere Man
find a new shop and have your born with engine rebuilt to OEM specs and forget about anything else
Old Nov 14, 2022 | 02:49 PM
xsray's Avatar
xsray
yes, I should shop around, I would rather have my original in her. I remember how well she ran 28 years ago, like me, she's a little tired now.
Old Nov 14, 2022 | 02:55 PM
silver837's Avatar
silver837
I think 10 grand sounds high. Does this include R &R ? What is he going to do . Is there a detailed list of parts and labor costs ?
Old Nov 14, 2022 | 03:02 PM
Tampa Jerry's Avatar
Tampa Jerry
If you are going to rebuild the original engine, make very sure the machine shop does not deck the block and remove the numbers on the stamp pad. I have heard that some shops can deck the block and save the numbers. Get it in writing and make sure the guy running the milling machine knows what you are talking about. Good luck. Jerry
Old Nov 14, 2022 | 03:11 PM
Audiophobe's Avatar
Audiophobe
Yes.
You'd rather have the original and so would you're car value.
I bet you could do allot better than $10k.
Old Nov 14, 2022 | 03:15 PM
xsray's Avatar
xsray
No details, I think he is just trying to feel me out to see if I'm willing to go with that. Yes R/R and new clutch. install.
He's always been a bit pricey, but very satisfied with previous work.
I'm going to contact a couple of clubs around here and get their input on good machine shops. I can remove and reinstall myself.
Old Nov 14, 2022 | 03:41 PM
drainbrain's Avatar
drainbrain
Geeez and they plumbers make money!
Old Nov 14, 2022 | 03:59 PM
GTR1999's Avatar
GTR1999
I suggest you stop and collect your thoughts on the car, what you want from it and then proceed to do a lot of homework, otherwise you are going to go down a steep, slipper, slope. I have been repairing the work of Corvette "experts" for most of my life and I have been around long enough to see scammers multiply with the start of the internet. It used to be just the local crooks taking the local newcomers' money, now they take it without providing any service at all.
If you can do the work and just need guidance that is the best approach. If you can't, for whatever reason, then you will be paying a lot and may not get what you think you're paying for. Original matching cars are still more valuable than crate engineer cars, finding a trustworthy mechanic or machinist is the larger issue. They're out there still but just not in the numbers that once were. $10k for a 60's Chevy engine in non-Drag Race application is too much. If it was a special production build that's different. I bet you're paying mostly hidden labor costs. Drag engines cost more than that and some of those are not so good, and I am speaking from past and present experience.
Old Nov 14, 2022 | 04:15 PM
xsray's Avatar
xsray
thanks, i needed that reality check, i will take some time to think about what I really want out of this.
To engine from Ecklers
Old Nov 14, 2022 | 04:22 PM
Avispa's Avatar
Avispa
This is a sensible approach if you're going to keep the car and drive it a lot. You can certainly keep your original engine in storage for the time at which you sell the car, if you ever do. Having a non-original motor in the car isn't going to hurt the car's value at all if you still have the original. If you don't like Blueprint Engines, there are plenty of other rebuilders. A huge benefit to taking the replacement engine approach and storing the original is that you remove any risk of blowing up the original, or the rebuild going haywire. Yes, the risk of that is tiny, but it's not zero. The market places such a premium on original engines in these cars that when you risk-adjust the car's value, it doesn't make sense to rebuild the original. Just store it. If you like the sound and performance of an L79 like vetsvette, then build an L79 spec small block.
Old Nov 14, 2022 | 06:11 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
As suggested, slow the roll! I agree that the price, without details does seem high, but you can enlighten us later. If you pursue rebuild, find three machine shops and visit each. Look for organization, how clean each is, will they explain the use of equipment. Some shops have "Clean rooms" for engine assembly. I followed this process in the mid '80's. Avispa has a valid point about storing the original and going with a Blueprint engine of your choice. Dennis
Old Nov 14, 2022 | 08:12 PM
GTR1999's Avatar
GTR1999
Good point on visiting several shops if possible. See what they look like and how they present themselves. A good machinist is probably booked out months, a hack may tell you a couple of weeks. I have some stories from over the years. Many of the places around here are out of business, either they couldn't compete with the internet's cheapo prices and work, or they were outright crooks. Many in this area had drug or alcohol issues as well, some would "lose" your parts.
