[C1] Blind attachment question
Old Dec 27, 2022 | 01:07 PM
Jhemp3's Avatar
Jhemp3
Default Blind attachment question
During my current carpet replacement (‘62), Ive found that the shifter/ashtray surround’s attachment bolt/screw holes have been enlarged. Hoping someone might have suggestions about blind attachment solutions. I would like to avoid crawling under the car and accessing nuts when removal is needed.
The modified holes are close to 7/16” in diameter. Thanks, Jim
Old Dec 27, 2022 | 01:27 PM
Vega$Vette's Avatar
Vega$Vette
Install Rivnuts. Also called threaded inserts
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
I believe the best way to solve your issue is to:
1) Clean the holes
2) Painters tape underneath the holes you need to repair Should be able to set the tape through the shifter / tray opening.****
3) Double Epoxy the enlarges holes to level and let dry for 24 hours
4) under drill the epoxied holes
5) Done
**** If tape positioning is not possible, the epoxy mixture should not lag down through the holes. if it does, mix a little more and fill the dimples then let dry and cure......
After looking at the C1 Plate attachment bolts/clips...........DO NOT FOLLOW MY DIRECTIONS! Your not fixing enlarged screw holes!!
Old Dec 27, 2022 | 01:35 PM
Jhemp3's Avatar
Jhemp3
Thanks, Vegas. Good idea. It’s amazing how you get locked in on something and miss the obvious. Your comment about the shifter opening is something I totally overlooked. I can work through the opening fairly easily and get to where I need to be. Thanks again. Jim
Old Dec 27, 2022 | 04:31 PM
DZVette's Avatar
DZVette
I made a home-made nut plate out of brass barstock and drilled and tapped for the screws. Attached it to tunnel with pop rivets.
Old Dec 27, 2022 | 05:19 PM
Jhemp3's Avatar
Jhemp3
Thats a neat professional job. Im a little ashamed because I took the Lowe’s took the Lowe’s approach. Seems to be pretty secure at this point we’ll see how it holds. Thanks for sharing. Jim.
Old Dec 27, 2022 | 06:16 PM
Hermn59's Avatar
Hermn59
Isn’t this what goes in the holes?
Old Dec 27, 2022 | 06:52 PM
Jhemp3's Avatar
Jhemp3
When all else fails, read the directions. Great post. Thanks, Jim
Old Dec 27, 2022 | 07:52 PM
vettepoor's Avatar
vettepoor
Active Streak: 90 Days
These are what I used on my 57 to capture the bolts. Just tap them into the fiberglass tunnel, they’re not going anywhere.
Old Dec 29, 2022 | 06:36 PM
Jhemp3's Avatar
Jhemp3
Blind bolt redo. Thanks DZ, great solution. Jim
Old Dec 29, 2022 | 11:27 PM
DZVette's Avatar
DZVette
Glad it worked out for you.
DZ
To Blind attachment question
