Ignition issue
Old Feb 12, 2023 | 12:22 PM
  #81
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
you know the parts store will have a set of points in stock and you could be enjoying your car in a half hour. why drag this out any further
Old Feb 12, 2023 | 12:33 PM
  #82
Spike66's Avatar
Spike66
Do yourself a favor Nowhere Man and push on.
Old Feb 12, 2023 | 12:43 PM
  #83
Vega$Vette's Avatar
Vega$Vette
99.9 % of issues with Pertronix are caused by improper installation. Points installed incorrectly will also cause issues.
I have points in my 67. I also have the knowledge, experience and tools to install and adjust them. That said When I need to replace them I'll go electronic. That's just me not saying electronic is a upgrade. But there is a good reason US car manufactures stops using points/condensor ignition almost 50 years ago.
Why?
"After 1975, most cars went to electronic ignition systems. Basically, electronic ignitions were "improved points." The principles were the same and it simplified the ignition system"
Old Feb 12, 2023 | 12:47 PM
  #84
Nowhere Man
Why?
there is no need to make a claim. we all know they all work. but no oem ever used these widgets. there is a reason. its been stated many times why. I am not here to hash it out over and over. to me this is just making things complicated in a very simple design. do what works. they all will get you where you need to be. I would jsut never over complicate things and be in this path. because they would be on the ground by now and I would smash them. but carry on and good luck
Old Feb 12, 2023 | 12:58 PM
  #85
Vega$Vette's Avatar
Vega$Vette
Did you miss the word simplify in my post? It does not make it more complicated. Don't have to set gap, don't have to set dwell don't have to worry about lube on contact nub or wear on distributor shaft where it contacts the points to open them.
If a guy comes on and asks for help with his points/condenser installation, I do what I can to help a guy figure it out. I don't tell him to rip them out and install electronic ignition and visa versa. That's all.
Old Feb 12, 2023 | 01:11 PM
  #86
USMC 0802's Avatar
USMC 0802
Veteran: Marine Corps
USMC
Concur 100%.
However, he can’t help it. Nowhere Man has an irrational hatred for non OEM components; uses dismissive terms like, “widget” and waxes philosophical regarding how you shouldn’t “fix what isn’t broken,”how “xxx is an answer looking for a question,” etc., all the while questioning posters’ motives, and not directly answering most questions or offering helpful advice.
Self awareness and playground skills are rare at times and need to be called out.
Old Feb 12, 2023 | 01:23 PM
  #87
Nowhere Man
you would be the first one
Old Feb 12, 2023 | 02:01 PM
  #88
Vega$Vette's Avatar
Vega$Vette
Serious? Not gonna debate this on another member thread.
Old Feb 12, 2023 | 02:03 PM
  #89
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Originally Posted by Spike66
With the help of Vegas$Vette, I did a deep dive into the distributor. What I found was telling to the quality of the work I paid dearly for and possibly the durability of the Pertronix module to operate under such an amateurish, shade-tree mechanic installation. The module was sitting on a rivet on the right side of the breaker plate, making for the wonky orientation as seen in an earlier photo. The magnetic ring was rubbing on the elevated right side of the module causing the clear tape ribbon to separate from the ring and grind away on the top of the module.
I’m going to replace the module kit outright and get further away from the bonehead’s curse.
Spike, I dreaded removing my distributor (MSD) too so I put pieces of blue painter's tape in different places and marked their alignment before I pulled it. Rotor orientation, vacuum canister, etc.
Went back in with no problem.
Old Feb 17, 2023 | 05:37 PM
  #90
Spike66's Avatar
Spike66
With the Pertronix module and coil installed the engine fired right up. Amazing what a properly installed module mated to the correct coil can do. Gee...it runs. Thanks to Vegas$Vette for walking me thru the process without having to pull the distributor. It can be done quite easily.
Old Feb 17, 2023 | 05:45 PM
  #91
USMC 0802's Avatar
USMC 0802
USMC
Alex,
Glad you got it sorted! Contrary to some of the poopy pants on this forum, the Pertronix is a good system.
Hat tip to Vegas$Vette - we’ll have to link up for a beer!
Old Feb 17, 2023 | 06:44 PM
  #92
Duck916's Avatar
Duck916
Glad to hear this all worked out for you!
Old Feb 17, 2023 | 11:20 PM
  #93
mudbone64's Avatar
mudbone64
From: I'd like to propose a toast... to internal combustion and wind in the face.
Adapt, improvise, overcome. I just love a happy ending. Props to Vega$Vette and Spike66 for staying with it..
