Irregular Engine Missing?
Old Apr 28, 2023 | 07:46 PM
64DreamMachine's Avatar
64DreamMachine
Classic Member
Default Irregular Engine Missing?
Is there a good first guess as to what is causing erratic, irregular, now and then missing/coughing/hesitation? My 110,000 mile 1964 0riginal L76 has been running like it was brand new for the past two years then suddenly I get sporadic hesitation? It really seems like water in gas and I hope that is all it is. However if it's mechanical, do I look at spark or fuel?
Thanks, Craig
Old Apr 28, 2023 | 08:03 PM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
Thanks, Craig
I think I'd start with the bulkhead electrical connectors which are known to work loose, corrode and cause sudden and related electrical system failure. Troubleshoot from there to ignition; switch, coil, points, wires, cap, rotor, ballast, any of which can be involved. In my experience intermittence is more likely electrical than fuel system on a stock vehicle.
Dan
Old Apr 28, 2023 | 08:10 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Always run clean fuel. Put a additive
in, if you think you have bad fuel.
Good luck
Old Apr 28, 2023 | 08:22 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
I would pull both valve covers and look
Old Apr 28, 2023 | 08:36 PM
64DreamMachine
Classic Member
Dan
Could be you're on the right trail. I did have "red wire syndrome" about 4 times or so and I put in a new Engine wiring harness but did not change the under dash wiring harness so one half of the bulkhead connector is older. I'll pull it apart and take a closer look.
Old Apr 28, 2023 | 08:38 PM
64DreamMachine
Classic Member
Good luck
That's a good point. I'll get something in the tank for moisture tomorrow.
Old Apr 28, 2023 | 08:42 PM
64DreamMachine
Classic Member
Look specifically for what?
Old Apr 28, 2023 | 08:54 PM
Nowhere Man
make sure all the rockers are where they should be
Old Apr 28, 2023 | 09:53 PM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
Is the miss more noticable on ecceleration? Something very simple to check is your ignition coil....
Old Apr 29, 2023 | 08:57 AM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
If something was wrong and one was turned, it would be more of a constant miss, not once in a while as OP says. Personally I'd put your suggestion a little farther down the list, and see if the problem was located before we got that far down.
Old Apr 29, 2023 | 09:27 AM
1Hotrodz's Avatar
1Hotrodz
Like other have said above, sounds ignition related or possibly bad fuel. For starters, check for moisture in the fuel tank and weak spark. Trace ignition power wire from Ign. Sw. to the coil and also ground side thru breaker plate. Not sure on Chevy but, most GM cars; the resistance wire for the coil power runs from the Ign. Sw. thru the firewall connector to the coil, whereas sometimes the resistance wire starts at the firewall or bulkhead connector. So if you just replaced wiring from after the firewall connector, it possible the wiring on the other side (interior side) could be suspect, namely the Ign. wire.
Old Apr 29, 2023 | 09:35 AM
Nowhere Man
not on Corvettes. they used a ballast resister.
Old Apr 29, 2023 | 09:49 AM
1Hotrodz's Avatar
1Hotrodz
Did not know that; thanks for clearing that up. So where is this ballast Res. located?
Old Apr 29, 2023 | 09:54 AM
Nowhere Man
on the drivers side firewall beside the master cylinder and wiper motor all but 64-67 TI cars are that way
Old Apr 29, 2023 | 10:01 AM
Chalie M's Avatar
Chalie M
Thanks, Craig
I had a sporadic miss, very slight pop thru the carb on my 65 L76 developed out of no where found the vac hose split on the underside of it I never would of saw it from looking at the top of it, something made me twist the hose around & found a split in it I quest that’s the side that see’s all the heat from the engine. I would verify all the basics (vacuum leaks, check carb base gasket also, spray a little carb cleaner at it etc.) first before I start pulling anything apart .
You could pop the fuel cap off & with a good flashlight see how the fuel looks? Never forget a long time ago changing out a electric fuel pump on a classic BMW after removing the pump under the back seat fuel tank access panel & looked down into the tank found remnants of water/rust very obvious by visual inspection..
Good luck, keep us informed.
Regards
Chalie
How old are the wires cap/rotor ignition items??
“ It’s the simple things that confound the wise”
let us know..
‘Chalie
Old Apr 29, 2023 | 10:05 AM
1Hotrodz's Avatar
1Hotrodz
Thanks Nowhere Man! Still learning new stuff everyday.
Old Apr 29, 2023 | 10:07 AM
64DreamMachine
Classic Member
No, I notice it most at low RPM, parking lot travel. Come in off the road and slow to find a parking place and get hesitation.
Coil and condenser are new.
To Irregular Engine Missing?
BLUE1972's Avatar
BLUE1972
Check the cap and rotor. For cracks , wear and carbon trails.
If yours has a ballast resistor check the output voltage and see if it varies a lot.
Old Apr 29, 2023 | 10:09 AM
Nowhere Man
just because its new doesn't mean its any good
Old Apr 29, 2023 | 10:14 AM
64DreamMachine
Classic Member
let us know..
‘Chalie
Plug wires 1000 miles old. Cap/rotor/points unknown. Will check these as I go down the list of suspects.
