66 Dash removal
What are your thoughts? I've also committed to all new wiring after noticing a couple splices, some hard insulation and even a bit of melt on the ignition switch....could have dogged a bullet there. Another thing, and there's gonna be a lot, is the gauges, the lower readouts are a bit rusty colored while the main speedo and tach are just slightly faded. I really don't mind the faded, but am leaning towards finding oem used to replace the ugly faces of the oil and temp. Clock also looks a bit faded, but I'm good with that also. I do want to get it back working.
This is a 425 coupe, so I don't plan on scrimping but I also won't likely be looking to show, just put it back on the street because we need more on the road!
On to the instrument cluster, it's such a pain to pull it out, you will want to go through it all now. The two main gauges have brand new faces available new for reasonable prices. Ive only had to replace one of the small gauges and I replaced the entire gauge...ammeter. I dont know if the small gauge faces are available if the gauge themselves are still functional.
The instrument cluster, next to the steering wheel, is the part youll be staring at 'each and every time' you get behind the wheel, so you'll really enjoy the view if you refurbish it all now.
Keep us posted on your progress, always like seeing an L72 brought back to its former glory.
Mike T - Prescott AZ
Pat
The only things I've purchased so far are the tailpanel bling and the front blinker assemblys.....all are top notch and I'm impressed, much like "trimparts" stuff. Still detectable to the informed, but nice. Those very minor differences I'm okay with IF i can't repair or restore my vintage parts.to perfect condition.
This dash is without flaws except it may be a slight bit "flattened" in color and texture from hand rubbing and sun. Since I do my own paint and body, I'll have to mask it every stage, which is a consideration also. Access to firewall matt, clean-up, and roughing in the new harness are lesser concerns.
Side note....I've seen the "ears" of dash module that are riveted to the a-pillars painted dash color, and plenty pics of them painted body color. I have an AIM, and "Technical Guide" but haven't purchased the NCRS judging manual......but will. My point....I haven't educated myself on the AO Smith means of assembly, but will. Just a bit of cheating by asking the forum beforehand. Also again.........can those big dash rivets be EXACTLY duplicated, they certainly look like hardware store variety 3/16" rivets???
This pic is just showing how nice new gauges are and the wiring is attached to the cluster. But you can't install like this. Oh yeah do your self a favor and put in a volt meter not the worthless battery gauge
And I still wonder why. The body was painted less interior by GM. So they had to paint those ears after assembly at some point. Wondering exactly when, where and how?
