[C2] 427 Casting number
The 9 and 351 look a little out of align.
https://www.2040-parts.com/3904351-1...gm-351-i28784/
https://www.ebay.com/itm/26535320409...kAAOSwXsBhYbfD
https://www.yenko.net/forum/showthread.php?t=158891
That does help. Seems they aren’t all perfect. I was just burned recently so I’m really gun shy.
If I had to do it over, I woulda just bought a nice 454 crate motor and dressed it up with correct looking stuff.
I wasn't suggesting resto mod for a mostly correct car, just that any old Mk IV 4 bolt main block will do the job, cost a whole lot less, and not send you to drinking if you put a rod through the side. Other than the casting numbers, they're all identical on the outside. It's not at all clear to me that a correct casting number, casting date, but not original motor adds enough value to the car to take the risk. Correct number and date parts are pricey, frequently not usable without major repairs, and as you already found out are often fraudulent.
I'm thinking about trying to find a correct numbers matching 427 to put back into it to make it as close to original as possible. For some reason, I
think that they stamped the VIN on the blocks at the time which would negate having a true numbers matching car. Is that correct?
Any ideas on where to look for a correct 427 engine?
thanks!
Raney
thanks!
Raney
You are correct that you won’t have a born with engine, but a number and date correct is still a good move. In my case, NCRS awards 350 points for the correct block with vin and Engine plant stamp, plus broach marks. The block i bought had been decked, so I will lose 25 for no VIN, 25 for no engine plant, and 38 for no broach marks. 88 total points.
If you are not going to have your car judged and you aren’t going to try and make it 90%+ numbers correct, I don’t think I’d chase down a date/numbers correct engine. Just my personal opinion.
I found two blocks in my 6 week search. One block I found on EBAY from a very reputable engine building company called Ross Racing. Jeff was top-notch to work with, honest and helpful. Tomorrow I will finish building my motor and probably install it. I had the engine sonic tested and it was exactly as Jeff said.
The other block I found was from a local machine shop here in Tucson. It was truly a diamond in the rough. I would look on EBay, bring a trailer.com, and start calling machine shops. I plan to build the other engine I have, and it will be all date correct with a clean pad. You could also post a WTB on this site too?
I hope this helps and good luck.
thanks!
Raney
If your car started its life on the west coast you may find your block in Idaho at this up coming auction:
