Starting Issues when hot
Get yourself a digital multi-meter to test electrical components. They are pretty inexpensive - most $30-$60 -- but you can splurge higher for more bells and whistles. Make sure the meter has DC volts, amps, continuity, and ohms. (I doubt a meter is out there without these, but I don't know that for sure.) Innova, Fluke, and Klein are reputable brand names.
Testing the charging system is easy to do and will help isolate any issues. I'll let others describe how to do that but a thread search will yield a huge amount of method instruction.
Yes original exhaust system.
No updates to any other electrical systems or accessories in the past 12 months. Just the new battery, alternator and starter.
It sounded like alternator to me but since it was so new and reading about heat sink on other posts, I realized I don’t know what I don’t know.
I haven’t had a heat sink issue since I purchased the car; however, we are having extremely hot days here in Texas.
thank you
As 67:72 mentioned, pick up a good Volt-Ohmeter and read up on it's usage. When you get one and can post some numbers for us, like battery voltage (engine off),
and running voltage will help us try to figure out if it's a connection problem or one of the components. Woudln't be the first time that a supposed 'new' part was not up to snuff.
By the way, when all this is going on, what does the dash Battery Gauge indicate?
Mike T - Prescott AZ
Being that it's a new alternator, start there. Was this problem what caused the alternator replacement?
Set the meter to DC Volts, hold the meter's leads to the battery terminals (black=negative, red=positive). If the battery has removable caps, make sure the electrolyte level is just to the split ring level, about 1" below overflowing. Only fill with distilled water if needed.
- With the engine off, the voltage should be 12.5v, +/- a few tenths.
- With the engine running, the voltage should be 13.8v to 14.4v, again, +/- a few tenths.
- Test the direct output of the alternator by touching the black to the frame and the red to the main large wire terminal on the alternator (under the protective boot). The voltage here should be nearly identical to the running battery reading. If not then there's an issue with the charging wiring to the battery.
This just started happening all the sudden. Today when they retested the alternator they couldn’t get a reading saying good or bad…very strange. The tester usually has a diagnosis in less than a minute. We waited for close to 5 min and no determination. So, we replaced it. Could the regulator be the issue or the heat here causing the problem?
Note: it is very hot here in Houston Texas averaging around 97. Car is running around 180 to 200 degrees.
I have an LS swapped 1972 C20 Suburban I use as a daily driver. When we moved to Austin two summers ago, I was having issues with the truck starting normally in the morning but if it was later in the afternoon with the temperature over 100 and I stopped to go to the store, or pick up the kids, the truck would not start again until it had significant time to cool down....sometimes multiple hours depending on the temp. I could hear the click of the starter, but it just wouldn't start.
I tried a new starter, multiple solenoids, read wires, tried a different battery and nothing solved the issue. At cars and coffee one morning, I described my issue to another local guy who daily drives an 80 series LandCruiser. He told me that he had been having the same issue and that his problem had been that the wire, running from the ignition switch to the starter solenoid was of a small enough gauge (from the factory) that when the wiring would get hot in the engine bay, causing the resistance in the wire to increase slightly, it would be enough to prevent the solenoid from seeing sufficient amperage to turn the motor over. His solution was to use the ignition wire to trigger a relay sending power directly from the battery to the solenoid.
Just to test the idea, I bought one of those 4 AWG jumper cables with the fused button that you can hook up from the battery to the solenoid to essentially "hot wire" the car from the outside.
https://www.summitracing.com/parts/oes-25331
I then drove the truck for the next week and sure enough, any time it wouldn't start, Id attach the two leads to the battery and the solenoid, turn the key to RUN, hit the botton, and it would fire right up.
Following suit, I ordered a Kaizen Speed solid state relay and 20 feet of 10 AWG TXL wire, using the purple ignition wire in the Painless Wiring harness to trigger the relay. Sure enough, the truck turns over quicker and starts faster, regardless of temperature, or how heat soaked it may be.
Hope that helps!
Hope that helps!
Car running tests: Battery 13.78. Alternator 14.15, 13.89, 13.68,
Car temp at 180 degrees. Battery 13.49. Alternator 13.6, 13.55
Car off and electric fan cycle: Battery 12.08. Alternator 12.13. (Fan cycles on and off until temp is below thermostats.
Car off & no more fan cycles: Battery 12.18. Alternator Alternator 12.2
***So the electric fan has been on car since I purchased it last year and has not ever drawn battery to a point of not starting easily.
Tried to start it after car cooled off and still slow turning starter. So, I hooked up the battery booster (set on 55 amps) and it started right up. Leading me to believe the battery isn’t getting enough juice to stay charged enough to start after driving it for awhile.
Dan has the theory of it being a weak wire to starter and when hot the problem rears its ugly head. Because the numbers move they way they do, like Factoid I think it could be the regulator.
Does this sound like the regulator is failing. It appears to be to be the original Delco Remy unmolested.
I can disconnect it and run same tests tomorrow.
Tried to start it after car cooled off and still slow turning starter. So, I hooked up the battery booster (set on 55 amps) and it started right up. Leading me to believe the battery isn’t getting enough juice to stay charged enough to start after driving it for awhile. Does this sound like the regulator is failing. It appears to be to be the original Delco Remy unmolested.
So I monitored the temps with and without the electric fan while driving. (Not sitting idle for longer than a light or so) The driving temp with the fan is spot on 180. Without the fan, the driving temp ranges from just a hair above 180 to about 200. Never more than half way between 180 and 220. Given the extreme temp this time of year ranging around 100 degrees and with these latest temp results with and without fan, I am not sure I really need it unless planning on sitting idle for an extended amount of time.
The fan is currently wired directly to the headlight junction box under the dash giving it direct power from the battery. I am thinking because the fan is running after car is off and pulling power, the car doesn’t have the amps to run fan and start the car while running. So, I have two questions…
1. What should be the normal operating temp of the water while driving on the hot summer days? (180 - 210)
2. Do I really need this fan and if so, wouldn’t it make sense to wire it to accessories so that it didn’t run after car was turned off? (Remember fan has its on thermostat and only runs while car is above whatever the setting is…
UPDATE TO THIS POST: One hour later, would not start. Same slow turning of motor. Fan is still disconnected…
So confused…
