Replacing Clock for C2
Old Aug 1, 2023 | 08:42 PM
gsk326's Avatar
gsk326
Default Replacing Clock for C2
After two years of searching, I finally found a replacement quartz clock for my C2 Corvette. I am going to get my old clock repaired (also quartz) so I have a back up.
Now I have to figure out how to remove the old one and install the new one.
I have seen some old posts on the subject. It appears removing the clips behind the clock (and not losing them behind the dash) and putting them back on when done is the hard part.
Does anyone have any good photo of what it looks like behind the clock so I can see what I am up against?
Also, any step by step instructions how to remove and put back the panels and glove box in order to reach behind the clock would be helpful.
Thank you.
Old Aug 1, 2023 | 08:44 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
after you remove the glove box assembly its very simple
Old Aug 1, 2023 | 09:50 PM
62Jeff's Avatar
62Jeff
This post by DZvette should help provide some insight. He wrote it to explain clock repair, but the first page has a good picture and diagram.
https://www.corvetteforum.com/forums...post1590857783
Old Aug 1, 2023 | 10:36 PM
jkuzzy's Avatar
jkuzzy
I added additional wires to help plug it back in since GM didn't give any extra wire behind the dash.
Old Aug 2, 2023 | 05:56 AM
Nowhere Man
just did this not too long ago. Didn't have any problems plugging it in
Old Aug 2, 2023 | 07:27 AM
Vega$Vette's Avatar
Vega$Vette
Clock takes about 15-20 minutes to R&R. Super easy. Like NM stated pull the glove box. Sitting in the pass seat reach in with you right arm. Unplug it and slide off the 2 clips. If you drop one simply pull the console side pane to retrieve it.
Old Aug 2, 2023 | 09:19 AM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
As long as you have small hands.
Old Aug 2, 2023 | 11:04 PM
jkuzzy's Avatar
jkuzzy
Mine was SO short of what I needed it wasn't funny....
Old Aug 3, 2023 | 06:13 PM
blitz10's Avatar
blitz10
I also extended my clock wiring. I also lost one of the clips, but had a spare. My problem was when I turned on my lights the clock would stop. One of the spades in the terminal was pushed back and not making contact. I had it a shop prior for A/C and transmission sealed on powerglide.
Old Aug 4, 2023 | 08:55 AM
59BlueSilver's Avatar
59BlueSilver
2023 Restomod of the Year Finalist
I had a little bit of trouble getting mine out.
Old Aug 4, 2023 | 05:53 PM
OldVetteguy84's Avatar
OldVetteguy84
Holy moley!
To Replacing Clock for C2
