Throttle return spring question
Old Aug 20, 2023 | 11:04 AM
ChrisBlair's Avatar
ChrisBlair
I've been doing this since 1989 and while it's not as long as some folks here, it's not a hot minute either.
I'd never dream of not having double springs and none of my old cars, from '66 to '78 drove a yard without them already being in place without me installing them. Not only is the redundancy a good idea and it's cheap and easy, if you want "correct" appearance for judging it's so easy that it's a no-brainier to just swap out as needed or wanted.
I have often wondered if in the mid 70s or thereabouts, it became just SOP for Mr. Goodwrench to install them when a car came in without the double spring, like a silent 'recall' for want of a better term.
leif.anderson93's Avatar
leif.anderson93
Originally Posted by jim lockwood
Same requirement is imposed by the organizations which sanction road racing events.
Whether mandated or not, having double return springs is just good practice.
Originally Posted by Pop Chevy
I drag race my 60 and the sanctoning bodys, tech inspectors REQUIRE a double spring.
Completely understand the safety implications when racing. OP hadn't mentioned racing applications. This question, like so many others here, comes down to "do whatever makes you feel good".
Old Aug 20, 2023 | 11:25 AM
tuxnharley's Avatar
tuxnharley
If you’ve ever had a broken throttle return spring when driving under acceleration I can personally assure you that the emotion that creates is exactly the opposite of
“feels good”!
Old Aug 20, 2023 | 01:36 PM
gbvette62's Avatar
gbvette62
Originally Posted by 65hihp
Been driving old cars since 1966. Never owned one with doubled up throttle springs. Never an issue.. Many also had single pot MC and drum brakes.. No issue there either.
I guess I've been one of the lucky ones....I count my blessings.
You've been lucky! While I've never had an accelerator spring break, I've had an accelerator cable break, a few brake failures and even a clutch fork return spring break once.
I had an accelerator cable break on my 71 El Camino, I don't want to think what might have happened if it hadn't had a good return spring.
I was on a road rally on a Saturday night with my Corvette club, when a rear brake line failed on my 62. I was lucky because the 62 has a good parking brake. And this was before cell phones! I was lucky, I found a pay phone near by and I called a friend to bring me some brake fluid and a vise grip. I clamped the rear hose closed, topped off the single reservoir MC, and limped to the rally end point to have a couple (much needed) drinks.
Another time I had a rear caliper seal blow out on a 74 Corvette on my way home from an IMSA race at Lime Rock Park. I had to drive the 200 miles home through New York City and north Jersey in Memorial Day traffic with just front brakes. The 74 was only 4 years old and only had about 30,000 miles on it. I had a dual reservoir MC fail once too, leaving me with just rear brakes.
I've drag raced and autocrossed, but I've always serviced and taken care of my cars too. Every problem I've ever encountered happened in normal driving, not on a track. Stuff happens and I learned long ago not to take anything for granted when it comes to cars.
