[C1] Generator Bench Testing
Old Sep 28, 2023 | 07:14 PM
Pierre's Avatar
Pierre
Default Generator Bench Testing
I am in the process of rebuilding the generator on my '60. I remember reading a while ago that you can bench test your generator by rewiring the wires connected to it. If I remember right, the generator would turn then backward at ~1300 RPM. Would anyone know the wiring configuration for this?
Old Sep 28, 2023 | 08:41 PM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
Put a battery or high amp power supply of 12 volts between Armature and Field terminals, either direction. If the armature, brushes and field coil are good, it will motor slowly.
Dan
Old Sep 29, 2023 | 01:38 PM
DZVette's Avatar
DZVette
See the attached pdf for info provided by Rich Mozzetta. First page describes "motoring" the generator as mentioned above
Dave Z
To Generator Bench Testing
