OK...whose pulled a standard 63-66 steering column?
I just had my column out a few weeks ago to replace the turn signal switch. My wire protector was all mangled and I didn't want to put it back in, so I simply taped the wiring harness to the top of the column and moved on. Maybe a "bubba" repair . . . but, I can live with it!
Tom
Tom
YES . . . the flat cable did fit, but I've had to replace the turn signal switch 2 or 3 times in the past 10 years, so I just decided to eliminate the protector. My car is no NCRS beauty queen!
I did this job a couple years ago and did it twice. Smashed/crimped the wires the first time. It's a frustrating job that is learn by doing. I have no secret to success. Not even beer helped.
It works and is undetectable
unless your letting folks crawl under your dash.
Again, they would have to know what they are looking for.
Wrap it professionally looking.
Tuck it in on the connection clip on the column and start the next repair
My thoughts on the matter
Marshal
My flat cable width - 0.625"
Wire duct inside width - 0.525" (at least 0.100" too narrow)
My escutcheon duct slot width - 0.675"
Wire duct outside width - 0.610"
This leads me to believe that the duct I received from Top Flight/Corvette Central is incorrect (too small). If someone could quickly take a caliper to their duct (that fits) for the outside dimension that would be telling.
If it is proven that my cover is too small, It would be a plus to know a source to get the right part...
Don't know if this any help but here are some shots from our '65.
I don't recall where we bought the wire mold (likely, Paragon, CC or LIC) and it was a long time ago.
I don't recall having to cram the harness ribbon into the mold.
The wire mold is about 5/8".
Dave Z
Dave Z
Here are a few photos of what I believe was a original, on a '66 std column. Note the wires are not ribbon. The plastic tube had a slit along the entire length to route the wires.
If the column is out it's easy to route the wires. If it's in, you need to release and pull all of the connector pins from the plastic housings so you can feed them through the rectangular slot in the hub and the cluster escutcheon, then reinsert in the plastic housings.
If the column is out it's easy to route the wires. If it's in, you need to release and pull all of the connector pins from the plastic housings so you can feed them through the rectangular slot in the hub and the cluster escutcheon, then reinsert in the plastic housings. /QUOTE]
Thanks Rich! I believe that this is the answer. The harness was very likely not originally a flat cable! It was individual wires. It seems that replacement turn signal assemblies started coming with the flat cable - and here we are. The column is on the bench now. I'm not going to overthink this any longer and will split off at least some of the wires and use the otherwise nice looking cover I bought....
My solution was to split off the two outside conductors, which allowed an easy insertion into the wire cover. Results show in the pix below...
