Using a newer jack for a C2?
Old Dec 6, 2023 | 01:51 PM
JohnnyRay's Avatar
JohnnyRay
Default Using a newer jack for a C2?
No real surprise that the jack and wrench were missing from my May 17th build 65 convert. I wouldn't mind sourcing a functional replacement, but not really interested in a $1000 "show jack". Are C3 jacks form/fit compatible on our cars? If so, how "new" could one consider for a functional equivalent? I see many of these available for $150 +/-
Old Dec 6, 2023 | 02:22 PM
Vet65te's Avatar
Vet65te
I've got '4' Midyears and only '2' of them have their original jacks. I use C3 Jacks in the other two and they will function just fine.
The C3 jacks, at least from what I read for '69 on, the base is a bit wider and they are longer, like easily a good inch or more longer. So, you won't be positioning
a C3 jack into the jack compartment like you would a C2 original jack. Mine are placed roughly diagonal in that compartment.
As to whether all C3 jacks are dimensionally the same, couldn't tell you but I'm pretty sure that one of mine is from a '76 and it fit fine too and the price,
maybe 3 years ago, was $75.
Mike T - Prescott AZ
Old Dec 6, 2023 | 02:26 PM
JohnnyRay's Avatar
JohnnyRay
As to whether all C3 jacks are dimensionally the same, couldn't tell you but I'm pretty sure that one of mine is from a '76 and it fit fine too.
I would want it to fit. Sounds like a 68 is the latest that would work...
Old Dec 6, 2023 | 02:36 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Corviar jacks are very close to mid year ones
Old Dec 6, 2023 | 03:01 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
There are several used scissor jacks of various makes on eBay. One in particular looks like a GM unit. Dennis
Old Dec 6, 2023 | 03:37 PM
JohnnyRay's Avatar
JohnnyRay
Looks close in terms of the scissor...but it lacks the "kick up" that the Corvette jack has...
JohnnyRay's Avatar
JohnnyRay
Send the link...or it isn't true!
Old Dec 6, 2023 | 03:44 PM
ifitgoesfast's Avatar
ifitgoesfast
I have a monster floor jack that has a max lift height of almost 30 inches, but at around 70 pounds and enormous size I can’t travel with it. A bottle neck is what I store in it.
Old Dec 6, 2023 | 06:03 PM
DZVette's Avatar
DZVette
https://www.oreillyauto.com/detail/c...corvette?pos=0
I used one of these for a few years with no problems. It fits in the C2 jack compartment and in the C1 spare tire.
I used it on the side of the road and I also have used it to jack the frame rail while the car was up on my KwikLift. Used carefully, I never had any issues with it.
The newer one looks similar to the one I bought way back when (see attached PDF).
If you are not looking for a Corvette "look-alike" jack, this one is a good serviceable unit.
My 2 cents.
Dave Z
Old Dec 6, 2023 | 08:12 PM
JohnnyRay's Avatar
JohnnyRay
I use a bottle neck to play slide guitar!
Old Dec 7, 2023 | 01:06 PM
phil2302's Avatar
phil2302
68 jacks are pricey. Almost as much as C2 jacks.
I leave my C2 jack home in a cabinet and have a modern day scissor in the car.
Old Dec 7, 2023 | 04:49 PM
CorvetteMikeB's Avatar
CorvetteMikeB
Old Dec 7, 2023 | 05:03 PM
Duck916's Avatar
Duck916
Originally Posted by CorvetteMikeB
I like to use those cheap C2 scissor jack knockoff's made in China when working under my 3,200 pound corvette too. I just sand off the new rust off the jack each year.
I don't use any jack, whether it be a scissors, hydraulic, American or Chinese, to work under my car. I do use a fairly inexpensive scissors jack for emergency tire changing, though.
Old Dec 7, 2023 | 05:23 PM
CorvetteMikeB
I was just joking. My garage is too small for me to work on a car underneath. I let the dealership do all my non-C2 specific repairs. I do the repairs that requires all four tires on the ground.
Old Dec 7, 2023 | 07:38 PM
JohnnyRay's Avatar
JohnnyRay
I was thinking earlier "you risk taker!" ;-)
I ended up getting a Triumph Classic compact/short lift with a sliding hydraulic jack for my garage. Works well for tight spaces, but a sports car is about all it will hold. The 65 is on it now!
I started this thread to see if there was an appearance and form factor compatible jack that I could reasonably source to throw in the compartment - just to complete the car with the accessories it came with when new. I don't care about matching dates or exact details. Sounds like a tough bill to fill....without spending a big handfull of bills!
Old Dec 7, 2023 | 07:57 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
I use a bottle neck to chug my tequila...playing guitar is much easier then.
Old May 21, 2025 | 05:36 PM
CorvetteMikeB
With a 20" hydraulic jack lift. How high off the cement garage floor can I expect to get my tires off the ground?
To Using a newer jack for a C2?
