[C2] Engine removal
Old Jan 24, 2024 | 08:40 PM
Redd Fox's Avatar
Redd Fox
Thank you
Old Jan 24, 2024 | 09:22 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Food for thought - if you ever considered putting in a removable crossmember, now would be the time to do it when everything is out. Hopefully there will not be a "next time", but if there IS.....
Old Jan 25, 2024 | 12:14 AM
Redd Fox's Avatar
Redd Fox
Great Idea, Thanks
Old Jan 25, 2024 | 07:56 AM
mudbone64's Avatar
mudbone64
From: I'd like to propose a toast... to internal combustion and wind in the face.
I've used levellers and carb lift plates and assuming you have help carb lift plates>>>>>>>>levellers. No chains and/or hooks to mess with that will scratch the engine or intake up. Less required minimum ceiling height and the lift plates are cheaper too.
https://www.corvetteforum.com/forums...imes-dead.html
See post #1.
