[C2] '67 Bolt Identification...please.
Old Jan 23, 2024 | 09:13 PM
KingRat's Avatar
KingRat
Default '67 Bolt Identification...please.
While working on my '67 chassis, I ran across some bolts that I seem to have forgotten to label. Anybody recognize these? Thanks!
Old Jan 23, 2024 | 09:30 PM
66jack's Avatar
66jack
top one is for the fuel line....
here's paragon bolt id and location...i cannot find the bottom ones location...open pdf in post #12
https://www.corvetteforum.com/forums...ect-bolts.html
see post #18 could be the same?
https://www.corvetteforum.com/forums...post1581411352
Old Jan 23, 2024 | 10:17 PM
KingRat's Avatar
KingRat
Thank you. I have been comparing bolts with the Paragon charts. I only have two of each size with the flange head and the fuel line bolts don't have a flange.
Old Jan 24, 2024 | 05:00 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
They where used in a lot of places like the female hood latch, steering column mounting etc
Old Jan 24, 2024 | 11:36 AM
KingRat's Avatar
KingRat
Thank you. I have those accounted for. These were with my engine bay bolts. Hopefully as things go back together, the answer to the mystery will reveal itself.
Old Jan 24, 2024 | 01:54 PM
66jack's Avatar
66jack
Then that 'fuel line' bolt should go by the fuel pump on the hard line
Old Jan 27, 2024 | 10:53 AM
Con's Avatar
Con
IIRC 5/16-18 and short are battery tray bolts
Old Jan 27, 2024 | 09:02 PM
KingRat's Avatar
KingRat
Found a picture from when we took the chassis apart. the 5/16-18 x 3/4 bolts are from the shifter bracket.
Old Jan 28, 2024 | 07:12 AM
Con's Avatar
Con
Always great to find the right picture.
Those bolts are common. On horn as well I think
To '67 Bolt Identification...please.
