Engine casting number
Old Apr 6, 2024 | 03:02 PM
Spowell637's Avatar
Spowell637
Default Engine casting number
The engine casting number on my 1963 corvette is 3782870.
i would be a interested in finding more about the engine/car.
Thanks in advance
Old Apr 6, 2024 | 03:09 PM
63driver's Avatar
63driver
There is also a date cast as well as numbers (two sets) stamped on the engine pad. Post those or pictures.
Old Apr 6, 2024 | 03:27 PM
Spowell637's Avatar
Spowell637
Numbers on the right side (rear) appears to g11124.
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
The 870 block was used from 62-65 for ALL 327 engines.
Old Apr 6, 2024 | 04:01 PM
Spowell637's Avatar
Spowell637
Numbers on right rear
Old Apr 6, 2024 | 04:04 PM
Nowhere Man
August 12 of 64. So that makes it a 65 model year engine. Anything on the stamp pad
Old Apr 6, 2024 | 04:06 PM
Spowell637's Avatar
Spowell637
Stamp pad is obliterated .
Old Apr 6, 2024 | 04:14 PM
leif.anderson93's Avatar
leif.anderson93
Steve,
See if you can clean it up and take some clear pictures. Pictures below of stamp pad area.
Old Apr 6, 2024 | 04:30 PM
65hihp's Avatar
65hihp
I think I'm seeing double,, could be the whiskey
Old Apr 6, 2024 | 04:45 PM
63driver's Avatar
63driver
The HP code looks correct. I can see the A/C muffler and the P/S. Should be a 4 spd car. I need to study the broach marks longer.
I think it's just a double tap at St. Louis, I'm ok with that.
Old Apr 6, 2024 | 07:05 PM
leif.anderson93
Put the bottle down, Don. It's an authentic double strike.
Old Apr 6, 2024 | 07:07 PM
leif.anderson93
It is and the broach marks are there...just faint. She's legit...Patrick Boyd and others have looked at it and approved
Old Apr 6, 2024 | 07:39 PM
Vet76te's Avatar
Vet76te
Based on the picture you posted, that is an “H”, which stands for August. The 12 is for the day of the month, and the 4 is for the the year.
August 12, 1964
Old Apr 6, 2024 | 08:19 PM
63driver's Avatar
63driver
Steve, you have received some excellent comments here, what are you looking to accomplish? You seem to have disappeared.
Old Apr 7, 2024 | 07:50 PM
Spowell637's Avatar
Spowell637
What would be the best method to clean up the stamp pad? And thanks for all replies.
Old Apr 7, 2024 | 08:01 PM
Nowhere Man
depends on what your trying to clean? if paint use a chemical type cleaner. never any type of abrasive
Old Apr 7, 2024 | 08:21 PM
Spowell637's Avatar
Spowell637
Thanks so much for your reply.
To Engine casting number
Old Apr 9, 2024 | 08:44 PM
76redvet's Avatar
76redvet
August 12, 1964
A 12 Aug 64 block/engine in a '63? OP said it was a 1963 Vette....
Old Apr 9, 2024 | 08:47 PM
Nowhere Man
they casted the block until 65.
Old Apr 9, 2024 | 08:54 PM
76redvet's Avatar
76redvet
Point was; if truly a 64 engine, it's not original to the vehicle.
