[QUOTE=Vette5311;1607719147]I use one of these. It’s about 1/4 inch thick so since you don’t have stock intake best check hood clearance as you may have to run a bit lower air cleaner.
what is the purpose of the thick gasket??? Thanks. Let me know
Not just thicker but the material acts to isolate engine heat from carb. Avoiding all sorts of heat/carb related problems.
Fuel boiling in float bowl, heat soak after sitting etc.
I had a similar problem when the car got hot. Also it was very hard to start after it was run and turned off for awhile. I found the carb float was set too high. Readjusted it to 1/2 inch and solved the problem.
