Clock running fast
Old Apr 29, 2024 | 06:38 PM
MJ1952's Avatar
MJ1952
Default Clock running fast
Why would my clock be running 2 hours fast?The clock was restored by Corvette Specialties of MD in 2003 so 21 years could be part of the problem.In the past I have been able to speed up a slow clock by winding the hands completely around but have never seen on run this fast.Any idea how to fix it or do I need to get it restored again?
Old Apr 29, 2024 | 10:17 PM
65GGvert's Avatar
65GGvert
2 hours fast over what period of time? How many times have you set it back and forth for DST? What year car? 59/60 at least has a speed adjustment on the face. C2's auto slow down when you set the time back and auto speed up when you set them ahead ( a little each time) . That doesn't work out very well with DST off and on, by the way.
Old Apr 29, 2024 | 10:22 PM
65GGvert's Avatar
65GGvert
How do you know it's 2 hours fast, maybe it's 10 hours slow?
Old Apr 29, 2024 | 11:33 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Old Apr 30, 2024 | 01:52 PM
MJ1952's Avatar
MJ1952
It takes about 24 hours to get ahead 2 hours.It is the original clock in a 1966.I just got the car March 22 so no DST adjustment yet.I think the car sat around a lot before I got it.Restored in 2003 and had 1,854 miles on it when I got it.
I Googled “C2 Clock Corvette Forum”(which I should have done to begin with) and saw a post by you from 2018 discussing this issue.I forgot about having a slow clock in a 1967 and being told how to correct.I will turn it back and see if that fixes it.I had several C2’s back in the sixties and it was just understood that the clock was wrong.
Thanks for the help.
Old Apr 30, 2024 | 04:50 PM
65GGvert's Avatar
65GGvert
sorry I can’t help. I can’t get your numbers to add up.
Old Apr 30, 2024 | 04:55 PM
Vettrocious's Avatar
Vettrocious
2017 C2 of Year Finalist
Time just flies when you’re having fun…
Old Apr 30, 2024 | 05:11 PM
68/70Vette's Avatar
68/70Vette
One solution is to have a crystal mechanism installed. The installation is pretty much transparent. I did this for my C3's. The only noticeable difference is that the second hand moves continuously. With the OEM mechanical mechanism, the second hand moves in one second like interval steps. So I guess for a NCRS judging event, you could loose a point or two here.
Old May 1, 2024 | 12:08 PM
Hashtater's Avatar
Hashtater
Default Time
Time is not static. I believe your car has a quantum physics issue. Besides, does anyone really know what time it is? Does anybody really care?
Old May 1, 2024 | 12:34 PM
ruxvette's Avatar
ruxvette
Well, it's about time, you know...
Old May 1, 2024 | 05:03 PM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
It sounds like you got to 88 mph. Mine is only accurate twice a day.
Old May 2, 2024 | 12:59 AM
silver837's Avatar
silver837
" Time has come today " !!!!!!!!!!
Old May 5, 2024 | 03:44 PM
66sixtaillights's Avatar
66sixtaillights
my '66 clock runs about 20 minutes fast over a days time. I have been running it backwards for about a year and it hasn't changed anything. some clocks will readjust speed by running them backwards or forwards. I was told this would help my clock, but it hasn't. I just reset the clock before I take the car out.
Old May 5, 2024 | 06:43 PM
PSB's Avatar
PSB
I would bet a little oil got on the Balance Hair spring.. So it beats much faster.
Old May 5, 2024 | 07:33 PM
Vettrocious
time, time is on my side…
Old May 5, 2024 | 09:58 PM
DinoBob's Avatar
DinoBob
There is a counterweight in the clock which can be adjusted. You have to open the clock shell.
Mine runs about 15 minutes fast a day, but I have not addressed it as I so often disconnect my battery and when I drive it, I usually have to reset it anyway.
To Clock running fast
