Things to Check
Old May 23, 2024 | 03:03 PM
LVMott's Avatar
LVMott
Default Things to Check
I am in the process of buying a 1959 Corvette (third try is the charm!). It was a driver but has been sitting for a couple of years. Besides changing the oil and checking the lubrication, in what order would you suggest checking/replacing parts to ensure safe driving?
Thanks!
Old May 23, 2024 | 03:07 PM
JF in MI's Avatar
JF in MI
Pro Mechanic
2023 C1 of the Year Finalist - Modified
Make sure the brakes do what they are supposed to do.
Old May 23, 2024 | 03:17 PM
LVMott's Avatar
LVMott
Copy that! What about bushings and ball joint, etc?
Old May 23, 2024 | 03:27 PM
jforb's Avatar
jforb
There are no ball joints, jsut metal bushings up front, rubber on rear springs. These usually don't mind sitting.
The brakes probably need maintenance (all the rubber parts go bad, and the cylinders get rust in them). Water pump bearings get tired, and seals leak. The fuel system can get pretty bad from sitting with old fuel in the tank, again rubber parts might all be needing replacement, and check the tank for rust or "stuff" growing in it.
Keep in mind that you don't know how long it's been that these parts had been replaced.
Old May 23, 2024 | 03:36 PM
JF in MI's Avatar
JF in MI
Pro Mechanic
As jforb says, front end parts don't deteriorate from sitting. That said, as I have posted many times before; I've never seen a unrestored C1 that didn't need some front suspension parts. I'm sure they're out there but I've never seen one.
Old May 23, 2024 | 03:44 PM
jforb's Avatar
jforb
My 62 has been doing pretty well without any suspension parts, just a toe adjustment. But it's an exception, I guess! goes down the road straight, didn't wear the tires funny after 15k miles, I'm happy with it.
Old May 23, 2024 | 03:49 PM
LVMott's Avatar
LVMott
The owner died awhile back. I don't know what parts he changed or upgraded. I won't have a look at it for a couple of weeks. I do know he drove it on a regular basis, and though it appear in really good shape, it definitely was not a trailer queen.
Old May 23, 2024 | 03:51 PM
JF in MI's Avatar
JF in MI
Pro Mechanic
Most certainly many can do that. The question is; have you everchecked your front suspension for worn parts?
Old May 23, 2024 | 03:58 PM
LVMott's Avatar
LVMott
I haven't had the chance to yet. But once I get it, that's on the TO-DO List.
Old May 23, 2024 | 03:59 PM
JF in MI's Avatar
JF in MI
Pro Mechanic
Yup, I bought mine out of an estate where the owner had also died 5 years earlier. Friends helping the widow sell the car claimed it to be perfectly road worthy. First thing I checked was the front end and, as expected, needed numerous parts replaced. Took it for a test ride and it would hardly stop. One front brake hose swelled completely shut the other partially shut.
Old May 23, 2024 | 05:14 PM
ChrisBlair's Avatar
ChrisBlair
Tires
Old May 23, 2024 | 05:37 PM
LVMott's Avatar
LVMott
Yeah, that is also on the List. Again, I don't know what he had on them or how many miles, or if they were maintained while in storage.
Old May 23, 2024 | 06:25 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Date codes are more important than looking good.
Old May 23, 2024 | 07:01 PM
wib1961's Avatar
wib1961
Check the frame for rot...especially the rear cross member and kick ups. And battery tray.
Old May 23, 2024 | 07:04 PM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
Drain the gas from the tank and flush the fuel line from back to front.
Old May 23, 2024 | 07:05 PM
jforb's Avatar
jforb
Of course I have....it all feels nice and tight.
Old May 23, 2024 | 09:02 PM
thoyer's Avatar
thoyer
Rear cross member is a very good point.
Steering wheel play, too much side to side while going straight could point to the need for a steering box overhaul.
To Things to Check
