[C2] choke
Old Jul 15, 2024 | 02:15 PM
xsray's Avatar
xsray
Default choke
The spring inside the choke housing is missing on my friend's 4150 carb. To install the new one do I tighten up the spring a few turns once in?
Old Jul 15, 2024 | 02:39 PM
65GGvert's Avatar
65GGvert
No, connect correctly and adjust. It can’t even be turned a full turn if you wanted to.
Old Jul 15, 2024 | 03:00 PM
R66's Avatar
R66
Are you adjusting a electric choke, I assume.
Anyway, you can find the video here - https://www.holley.com/support/carburetor/
Old Jul 15, 2024 | 03:53 PM
65GGvert's Avatar
65GGvert
What difference is there in the spring setting for an electric choke?
Old Jul 15, 2024 | 04:29 PM
Powershift's Avatar
Powershift
NONE.............as you well know.
Larry
Old Jul 15, 2024 | 09:26 PM
R66's Avatar
R66
Holley Instructions for setting the electric choke:
https://documents.holley.com/199r8000-4.pdf Step 17 for adjustment.
Old Jul 15, 2024 | 10:09 PM
65GGvert's Avatar
65GGvert
so, adjusted exactly like a stock choke.
Old Jul 16, 2024 | 08:04 AM
R66's Avatar
R66
Basically the electric choke works just like the old chokes fed with a heating tube except the heat is supplied by the electrically heated element in the housing. It becomes a problem if you leave the key on and it opens the choke on a cold engine as it doesn't depend on engine heat. I have one on the 68RS as the C3B intake does not have a mounting for the divorced choke spring. I don't like them, but they are better than nothing, Chrysler used them for years.
Old Jul 16, 2024 | 08:41 AM
xsray's Avatar
xsray
Perfect, Thank You.
Old Jul 16, 2024 | 09:18 AM
65GGvert's Avatar
65GGvert
my point was his question was putting the spring in and adjusting the choke. It doesn’t matter whether it’s an electric choke or a stock choke. He just needs to put the spring in and adjust it. The answer to his question was “no” to turning it a few rounds and then adjusting it.
To choke
