No, Redbird was asking me if I had to drill the holes for my conversion. Mine is a ‘64 and I had to drill them myself.
John, It wasn’t too difficult, I just mocked up the collectors to the manifolds and paralleled the pipes to the frame. Positioning the holes is pretty self explanatory. I can give you my measurements if you need them. JC
Is there a preferred vendor for a side pipe set?
I’m on the cusp of ordering a set & would welcome insight. (Pipes, covers, trim, hardware)
I also heard many vendors are pushing “clampable” sets as it saves on shipping & might be slightly easier to install.
John, let me know if this doesn’t make sense. I took a picture of the factory hole and its measurement from the end of the frame on my car. The keyhole slot I cut is centered under it. (Pictured) The distance center to center of the two holes is approximately 2 3/4 inches. The dimensions of the keyhole slot I cut is pictured. I made an aluminum template that I used to mark the hole to cut then just flipped it over and repeated it on the other side. If you need a better explanation just let me know. I can mail you my template if you want it. Jeff Frame to factory hole Center Center Center to Center Centered under factory hole Keyhole dimension Keyhole dimension Keyhole dimension Template Template to help me keep the slot parallel to the frame when cutting
