Differential Fluid Change
Old Oct 11, 2024 | 08:41 AM
MrHix's Avatar
MrHix
Default Differential Fluid Change
I have a Superformance 1963 Grand Sport and want to change the diff fluid. There are 3 plugs on the passenger side of the diff. I think the top one is for filling/return from cooler, the middle one is for send to cooler, and the bottom one is for draining. Can anyone confirm this?
Cheers,
MrHix
Old Oct 11, 2024 | 09:08 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
You'll get the best answers if you provide pictures of the differential area and of the plugs you mention.
For that matter, does your Superformance GS use a C4 differential or a C2 differential?
Old Oct 11, 2024 | 10:13 AM
MrHix's Avatar
MrHix
I believe it is a 63 - 79 (?) but it has a cover that I can't find with Google search.
Thanks Jim!
Old Oct 11, 2024 | 10:52 AM
GTR1999's Avatar
GTR1999
That is not a real GS diff, as you probably know. I don't know whose cover that is. Does the car have the tubular frame as the originals had?
Old Oct 11, 2024 | 11:00 AM
MrHix's Avatar
MrHix
It has a full tubular chassis and is built by Superformance in South Africa.
MrHix
Old Oct 11, 2024 | 11:27 AM
jim lockwood
The cover is a custom casting by Superformance and is intended to resemble the covers used on the original Grand Sports. The tube frames are similar to the originals but miss on some important details.
Old Oct 11, 2024 | 11:33 AM
GTR1999's Avatar
GTR1999
the originals had air jacks built in, does this one have those?
Here is the one I rebuilt years ago.
Old Oct 11, 2024 | 11:34 AM
jim lockwood
Cheers,
MrHix
Are the three plugs you've mentioned all on the passenger side of the aluminum rear cover?
Assuming so, the bottom one would be the drain. The fill plug will be found on the passenger side of the iron differential case.
Old Oct 11, 2024 | 12:39 PM
MrHix's Avatar
MrHix
All three plugs are on the passenger side of the cover and I can't see any plugs on the driver's side cover or case.
MrHix
Old Oct 11, 2024 | 02:06 PM
GTR1999's Avatar
GTR1999
I'm only going to guess here, but the originals had taps for oil cooler lines. I suspect that cover has the same with the fill plug above it- as you think. I would have tapped the bottom of the housing for a drain as I have for 100's of them so far. Makes it a lot easier to change the hole at the lowest point. I think if you pull the lower plug you can drain most of the oil out.
To Differential Fluid Change
