[C2] Engine stamp question
Old Feb 1, 2025 | 09:32 AM
C2W85's Avatar
C2W85
Default Engine stamp question
Hi all. Really appreciate how helpful everyone is on the forum. Came across this original 1966 C2 L79. Owner had it for 20 years and has original sale sheet from 66. However engine stamp looks different from others I’ve seen, particularly the 8. It’s also stamped at a slight angle versus the vin. Curious for anyone’s thoughts. Really appreciate the help.
Old Feb 1, 2025 | 09:42 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
the assembly stamp was stamped at the Flint plant. while the vin stamp was done at St Louis after it was assigned the car. to me the "T' looks off. but I'll let others chime in. do you have good clear pictures of the paper work?
Old Feb 1, 2025 | 09:57 AM
SupremeDeluxe's Avatar
SupremeDeluxe
The "8" and the "O" look odd. I don't pay a lot of attention to 66's, maybe those characters were used at that time.
Old Feb 1, 2025 | 10:04 AM
Nowhere Man
like any other stamp until you can look at known real stamps from the same day I would say those characters are typical
Old Feb 1, 2025 | 10:36 AM
kenba's Avatar
kenba
From: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
And pray tell how do you know which stamps are real.Blocks have been restamped since the 70'S.
Old Feb 1, 2025 | 10:38 AM
Nowhere Man
that's a very good question and be best answered by the guy who ask you to pay for his services on that that has thousands of stamp pad pictures on file
Old Feb 1, 2025 | 10:51 AM
gbvette62's Avatar
gbvette62
I have no problem with that pad. The surface looks good, as does the stamping. I have no problem with the "0" and "O", they are known to have been interchanged for each other in stampings, just as "1" and "I" were often interchanged and "6" and "9" were often inverted to be used for the other. The "8" is a little funky, but I think there were a couple different fonts used too.
Old Feb 1, 2025 | 11:11 AM
Lotsacubes's Avatar
Lotsacubes
No expert but I follow these posts with curiosity and rarely comment. When this question comes up I always look at/for the broach marks first. Are there clean, parallel broach paths and do they continue thru the stampings. To me that’s the first clue to originality. Then if really motivated get the book out on the letter shapes…rarely that interested. These broach paths are awfully faint. Hints and learer around the VIN. I’d at least ask for another picture from other angles, then go to the stamp book if serious before paying for an expert. Larry
Old Feb 1, 2025 | 12:00 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
If you have multiple examples from the same day the characters, flaws, and spacing should be the same. Even a few days apart will have the same F, month and possibly one or two characters for the day.
I envision a tray of characters (mixed fonts with various stages of wear) that the gang holder was loaded from. The person changing the gang stamps just picked out, say a random 0 character from the compartment. That's why you can have two differently shaped 0s. The individual blocks can also have wear on the sides such that they sit crooked compared to their neighboring blocks. That's where seeing other examples from the same time period is the gold-standard for determining authenticity.
Just to add an example and an endearing quirk to this: My '67 (and others here on the forum) have an upside down 8 in their VIN (from #18,000+).
Old Feb 1, 2025 | 12:12 PM
barkingrats
The lighting angle here is pretty harshly over-head which will wash out texture.
I have long wondered about the broach marks over time. I understand the broaching machine was huge with many multiples of engines going through at a time, but they must have had down-time to dress or change the broaches. As the broaches wear, the blocks are going to exhibit a different, heavier scratch pattern than when the broaches had new edges yielding finer lines.
Old Feb 1, 2025 | 12:28 PM
C2W85's Avatar
C2W85
Default Close vin stamp
I actually was able to find a close vin engine stamp on C2registry. Definitely some similarities. The 3 the I the F the O. The H is a little different.
Old Feb 1, 2025 | 12:39 PM
barkingrats
I believe they had multiple gang stamps set up for the different engine codes, and, being that they had to remove the engine code (HE) when the date changed, it's plausible to me the guy pulled another random H from the bin.
If you're curious about the small-block production, here's a great write-up by John Hinckley, who was there and is a widely respected authority on Chevrolet processes. Unfortunately he died just a couple years ago, but he wrote many articles and answered many forum questions here and on the Camaro sites.
File Type: pdf
Old Feb 1, 2025 | 05:10 PM
thoyer's Avatar
thoyer
Keep in mind the interwweb is full of engine stamp pictures. You need to be sure what you are comparing to is a REAL stamping, otherwise................
Old Feb 1, 2025 | 06:32 PM
barkingrats
Let me add that the VIN stamps were done days or weeks after the engine stamps -- and at a completely different location. Two engines can have sequential VINs but have engine assembly code stamps days/weeks apart. For direct comparison, you'd be looking to find engine assembly stamp pics with the same date and engine option.
Thoyer brings up a good point that a single comparison stamp pic won't offer much if there are any significant differences because you won't know which is the genuine stamping, if either. However, if the match between the two is nearly identical with similar characteristics, they're both likely authentic. (Two restamps looking the same would be pretty difficult to pull off unless done by the same forger.)
Old Feb 1, 2025 | 07:09 PM
Nowhere Man
the op noted an original sales sheet. this might be a clue on this car in question
Old Feb 1, 2025 | 09:01 PM
C2W85's Avatar
C2W85
what would you be looking for? It has vin on it. Any other clues?
Old Feb 1, 2025 | 09:06 PM
Nowhere Man
if it's really real or fake.
To Engine stamp question
Old Feb 1, 2025 | 09:18 PM
67/427/1 owner's Avatar
67/427/1 owner
2nd Gear
Cast date on the block / Vin on the frame if it has one and the production date of the car. That can narrow down the authenticity as well. I think its a bad restamping job.
Old Feb 2, 2025 | 07:30 AM
C2W85's Avatar
C2W85
Could you be specific as to what you would look for on the paper work to determine that?
Old Feb 2, 2025 | 08:11 AM
Nowhere Man
Wording and fonts
