My guess is factory defects. Other not likely problems, cap not latched on squarely, rotor contact, bushings worn, etc. but would expect it to be chipped across the total face of the contacts.
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Originally Posted by old stingray
It’s basically showing you that it’s time for a new cap.
We used to just file them lightly to smooth them out, including the rotor button contact, just like we filed points back in the day, and kept using them. Just don't significantly reduce the contact thickness, as that would increase the gap the spark needs to travel. As long as the engine is firing correctly, they're fine even if not pretty after awhile.
I guess I just never noticed it before. I'm going with "factory defect". Order a ACDelco Distributor Cap - D308R. Made in Warren Michigan or Kung Pow... I'll check either way
I did the same years ago,had to stretch every dollar?
Mexico? Ok, whatever. At least it's perfect inside and out.
