[C1] Tachometer Dead
Old Jul 31, 2025 | 12:44 PM
Eric Sakai's Avatar
Eric Sakai
Default Tachometer Dead
I Noticed tachometer not moving.
I checked if cable was disconnected from generator, looks OK.
Where or what could be the problem?
Generator is a few years old, as new rebuilt.
Thank you.
Old Jul 31, 2025 | 06:14 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I'm a little out of my element here as I haven't worked on a generator tached car in 40 years! And, I don't know the year to year changes for them.
Pull on the generator end of the cable -- if the cable is broken, part of it will slide out. You'll then have to remove the cluster to get the other half out and slide a new one in.
If you don't get a section out, we'll assume it's in one piece, so try chucking the end of the cable to a reversible drill and seeing if the needle moves. (I don't know which way the drill needs to turn to make that happen - I think counterclockwise.) If the needle doesn't move, it's time to remove the cluster to investigate further, if it does move, then the issue has to be in the generator's cable drive.
Old Jul 31, 2025 | 09:44 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Video I did a few years ago for a SACC tech seminar
Old Aug 1, 2025 | 12:50 PM
DZVette's Avatar
DZVette
Throwing in the attached PDF to add to Fred's nice video.
Dave Z
To Tachometer Dead
