Rear leaf spring
Old Sep 2, 2025 | 11:36 AM
67green's Avatar
67green
Default Rear leaf spring
My 67 coupe leans ! "+ lower on the drivers side in the baack. . I have all new rubber bushing, the differental mounting cross piece is not crushed, the sombreros are ok shape. I turned the passenger side leaf spring 1/2" from the bottom but the drivers side nut had to be turned uo to 1-1/2"+ it was still not level after thisadjustmentel ....Do I need a new 7 leaf spring to correct this problem of mine.???
i nee
Old Sep 2, 2025 | 11:55 AM
67's's Avatar
67's
Check your Shocks
Old Sep 2, 2025 | 12:00 PM
67green's Avatar
67green
I didn't think shocks could hold up the rear end that much, But ca n check then...Thanks for the Idea.....Still wondeing how to know if rear spring is good??
Old Sep 2, 2025 | 01:11 PM
leif.anderson93's Avatar
leif.anderson93
Take a picture of your rear spring (like the picture below courtesy of Doug Amick)...is your spring "level" all the way across, or is one end lower than the other. These cars from the factory had slight differences side to side.
Old Sep 2, 2025 | 01:13 PM
Duck916's Avatar
Duck916
Shocks don't support the car unless you've got airshocks or the equivalent. But it's possible that one of them is not fully extending. If, after removing both shocks the car is still not level, you could try flipping the spring to definitively confirm it has lost strength on one side. I have to say, though, that seems unlikely to me.
Old Sep 2, 2025 | 02:24 PM
ricks327's Avatar
ricks327
It would help to see rear and side photos of the car. Does the spring look like an original/old spring?
Old Sep 2, 2025 | 03:26 PM
Tampa Jerry's Avatar
Tampa Jerry
Did you change out your front springs? Jerry
Old Sep 2, 2025 | 05:30 PM
67's's Avatar
67's
I had a bad shock, and the car sat 2 inches lower on the side it was bad on.
Old Sep 2, 2025 | 08:09 PM
anyChevy's Avatar
anyChevy
It's possibly (and more likely to be) a sagged drivers side front coil.
I would jack it up dead center of the rear spring plate with something narrow and measure the front.
To Rear leaf spring
