[C1] Seat installation
Old Oct 29, 2025 | 08:57 PM
prestige6's Avatar
prestige6
Default Seat installation
I can get the seat tracks in the rear but I can't get the front tracks to move far enough to bolt the front in. What am I missing.
Old Oct 29, 2025 | 09:10 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
must be stuck, try some spray lube on the tracks
Old Oct 30, 2025 | 06:57 AM
dmtparker's Avatar
dmtparker
I used a big phillips screw driver through the hole in the track and into the bolt hole to pry them in to the rear enough to line up the front screws.
Old Oct 30, 2025 | 07:12 AM
R66's Avatar
R66
Is the carpet removed in the area of the rear seat track? The carpet can be forcing the track up and preventing full movement.
Old Oct 30, 2025 | 08:56 AM
Corvette4me!'s Avatar
Corvette4me!
I'm sure you've done this, but once the back of the tracks are slipped in the rear mounts, you have to slide the seat back all the way. If that doesn't do it you might attach a photo with the seat out to see if your rear mount bar looks like others. I have to pop my seat out every time I work under the dash and the older you get the harder that is.
Old Oct 30, 2025 | 03:41 PM
DZVette's Avatar
DZVette
Here's some shots from our '60.
More info in the attached PDF
Dave Z
File Type: pdf
Old Oct 30, 2025 | 05:10 PM
prestige6's Avatar
prestige6
Only thing is that a 62 the seats are one piece the cushions don't come off the frame like the early ones like 57,58
Old Oct 30, 2025 | 07:16 PM
Leo Guggenbiller's Avatar
Leo Guggenbiller
I had to lightly tap my tracks rearward when I replaced the carpet. Have pulled them out since initial installation and they argued a little,but install and remove without issues since.
Drive em safe
Leo
To Seat installation
