[C2] Another TKX question.
Currently 70 mph is about 3500 rmp. The .81 will change that to about 2835. A .68 5th would be about 2135 rmp. My thinking is the .68 would be to high a gear fo use with out shifting down to 4th when I want the power. Yes?
Another question. I have the C3 crossmember on the stock frame. Will mounting a TKX on a C3 crossmember instead of the stock crossmember be a problem ?
Popular Reply
American Powertrain has the complete C2 Tremec conversion kit and they also sell a removable cross member for easier install and/or if for whatever reason one needs to pull the transmission.
Cliffs Notes: get the .68 OD. The .81 would leave you wanting more IMO.
1) TKO 5-speed with .82 5th gear and stock 300 hp 327
2) TKO 5-speed with .82 5th gear and 424 hp 383
3) T5 5-speed with .68 5th gear and 424 hp 383
With your 3.70 rear and 383, I would definitely recommend the .68 5th gear. Even my stock 300 hp engine seemed like it could easily use more than the 0.82 5th gear. The 383 has no trouble with the .68 5th gear. Both configurations could comfortably drive as low as 40 mph and still accelerate without downshifting.
For any stock V8 Corvette (except maybe those with the high overlap 30-30 cam), I think the 0.82 5th gear is only appropriate for rear end ratios of 3.08 or 3.36. Unless the cam in your 383 is really aggressive (more than 235/235 duration on a 110 LSA), I think your 3.70 rear is just fine for the 0.68 5th gear.
Regarding the rear crossmember, the center area for the C3 transmission rear mount differs slightly from the C2 center area, and the bolt-on rear mount bracket is different. To get a C3 crossmember to work for a TKX conversion in your C2, all you need to do is order the C3 rear mount bracket instead of the C2 bracket.
Play around with this a little.
https://tremec.com/aftermarket/resou...io-calculator/
Tom
The .64 is too much drop. The .81 still seems to turn new parts into old parts faster.
I have a new .68 ready to install with 3.70 gears.
I do believe that .71 or .72 would be interesting to test but I think the .68 will likely be fine. I have side pipes so right now at 75mph the rpm’s are 3500 ish and it is roaring.
The .68 should clam things a bit and if I need to go, I can always downshift:-)
I used the Tremec calculator and my physical tire size is 25.5 inches.
The M21 is 3200 rpm at 65 3675 rpm at 75 mph
.81 is 2575 rpm at 65 2950 rpm at 75 mph
.68 is 2100 rpm at 65 2500 rpm at 75 mph
I live very rural and expect to be driving about 70 mph most of the time at about 2350 most of the time. Only city driving would be Lincoln or Omaha. Not to often. Long trips at 2500 sounds better than 2950. Yes ?
Cheers.
Go look at the torque curve on your BP 383. It is fairly flat and is mostly all-in at 2500rpms.
So as you are cruising in 5th you will have good acceleration without downshifting and if you want to hammer down, you can grab 4th and be gone. The strokers are great for the OD transmissions because they make good power down low.
So in my opinion, the .68 is prolly the better choice for overall drive ability.
I think the .81 is good if you need to keep the engine wound up for something like auto crossing. But if you aren’t auto crossing, I see no need to turn the rpm’s higher than necessary.
When I recently went to order, I called Silver Sport and talked to Shane and he had good thoughts about the different OD specs and how to think about them and how they execute. I too was dead set on the .81 and backed off to the .68.
Cheers!
TKX has .068 5th gear OD . Tremec 600 offers 0.64 5th Gear OD.
Then we have different engines ...rear gears ...tire diameters all which effect highway rpm.
My BP 383 has the Tremec 600 with 0.64 5th OD + 4.11's out back.+ a bit taller rear tire.
It has no problems on a highway with the Tremec 0.64 OD. I'm in 5th gear around 65mph due to the ratios below:
At 60mph it's at 2000 rpm
At 65mph it's at 2150 rpm
At 70mph it's at 2350 rpm
At 75mph it's at 2500 rpm
Tremec's Website has a Gear Ratio vs RPM vs Tire Height calculator:
It's a plug & play that calculates all the factors including different Tremecs for each set up:
