So I hadn’t been doing any night driving,and by accident I discovered my dash and taillights were out. After chasing wiring and fuses without any success I decided to pull the light switch out,took to the bench and clean it up real good with some electric contact cleaner re installed and pow all the lights work now. If they should ever go dark again the switch is where I’ll start so much easier than messing with all the other junk. Anyways just a heads up in case your lights should go dark.
Too funny. I hadn't' been doing any night driving, either. I came home last week in 'twilight' and my headlights wouldn't open. I fixed it. Tonight I came home, in the dark, and the headlights opened but...whoa, I had to stand up on the seat to see where they were shining. Headlight adjustment time tomorrow.
Yeah I’ve seen where there seems to be a lot of the dash light issue,like a dummy I should’ve started at the switch and had it fixed in 20 min instead of crawling under that dash and twisting my old body like a pretzel.
