[C1] Side view mirror
Feb 18, 2026 | 01:31 PM
Side view mirror
What’s the process or trick to removing the drivers side view mirror from a 1962?
I need to remove the mirror to repair small dent in back of housing….
Feb 18, 2026 | 02:14 PM
On my '64 there's a lockscrew ( I believe an allen?) near the base that allows the main mirror housing to be removed.
Mine are aftermarket though.
Feb 18, 2026 | 03:56 PM
Here’s a shot of my ‘62.
There is a screw/bolt in the base.
Feb 18, 2026 | 05:14 PM
Maybe I didn’t explain very well
im wanting to remove the “mirror” from the drivers side view mirror.
i already Have the mirror off the car….
Feb 18, 2026 | 05:47 PM
If it has a snap ring holding in the glass, see the attached PDF for some tips.
Dave Z
Feb 18, 2026 | 07:08 PM
Thanks for the info but unfortunately, my mirror does not have a snap ring holding it in. I believe it may be pressed. This is a 1962
Feb 18, 2026 | 07:31 PM
Quote:
Originally Posted by
Old Vet
Possibly not a factory stock mirror...replacement maybe??
Feb 21, 2026 | 12:12 PM
Side mirror
The back is press fit around the mirror. I tried to separate the 2 pieces on my 1960 and it was a disaster.
Feb 24, 2026 | 01:05 PM
Hey Dave, what size screw did you use and what size hole did you drill.
thanks
Feb 25, 2026 | 03:43 PM
John,
Unfortunately, I don't recall the size of the screw that I used to do that job.
I'm thinking it might have been a 4-40 as that's what I had on hand with the tap to go with it.
How large is the cross-sectional area of the top of the stud that was peened over?
