[C1] Another odd Modification
Old Feb 23, 2026 | 03:59 PM
rcb2's Avatar
rcb2
Default Another odd Modification
This is another modification I found on my 61 fuel car's T-10 tail housing mount in addition to the lower front shock mount
mod I posted earlier. Is this a factory or racer mod ?
Old Feb 23, 2026 | 06:01 PM
61corv's Avatar
61corv
Commonly used in aviation to safety wire bolts so won’t come loose and depart… and used in racing too. Not factory.
Old Feb 23, 2026 | 06:19 PM
ChrisBlair's Avatar
ChrisBlair
That wouldn't pass any FAA or IPC inspection that I ever heard of, but, I suppose it's better than nothing for the short term, although it probably gave a false sense of security. I will say in my opinion that the wire did nothing the torque didn't do in this case.
Old Feb 24, 2026 | 09:30 AM
Jaguarmaven's Avatar
Jaguarmaven
all four of the E types that I restored had safety wired as shown in this picture on the brake calipers. The picture that the OP posted probably was for looks more than anything else. Don’t think it would’ve prevented any of those bolts from loosening up
Old Feb 24, 2026 | 11:01 AM
ChrisBlair's Avatar
ChrisBlair
Correct. The wire in the photo above will hold the bolts in tension so as to always apply force to 'tighten'. The 'pigtail end' is also not too long and cannot catch on anything or cause injury. No nicks, etc. This is the correct way to apply. Safety wire also needs to be pliable and conform to what it is securing and this is also shown in the photo.
The wire in the photo in question can never do that.
Old May 18, 2026 | 10:26 PM
John S 1961's Avatar
John S 1961
Torque provides for the required clamp load the wire is so vibration will not back it all the way out.
Old May 18, 2026 | 10:41 PM
QIK59's Avatar
QIK59
Some clueless wannabe racer thought this is something he should do - what a joke !
Old May 19, 2026 | 11:37 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
RCB, what's been done to keep those bolts from backing out is, unarguably, ugly. That said, it WILL be effective in keeping the bolts from loosening simply by virtue of the very heavy gauge wire that's been used. The Debbie Downers are merely going apoplectic over cosmetics.
Old May 19, 2026 | 01:06 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Those of us who retired from working on USAF(B52) and WWII(A26) planes, would frown on the above safety wire method.
BUUUUUUUUUUT, as Jim pointed out, it would work.
Old May 19, 2026 | 08:36 PM
QIK59's Avatar
QIK59
IF the bolts came loose......................
Old May 20, 2026 | 05:42 PM
chrisheinis's Avatar
chrisheinis
If then what?
Old May 20, 2026 | 08:20 PM
jim lockwood
Originally Posted by chrisheinis
If then what?
Nothing.
The wire in the picture is so stiff it would prevent the bolts from backing out.
To Another odd Modification
