Grounds
Old Mar 3, 2026 | 08:06 PM
GVXCorvette's Avatar
GVXCorvette
Default Grounds
I'm adding a new layer of grounds to what should have been an original car. The AC needs a couple of grounds. Is there a good photo or drawing of grounds in a 1962 C1? I'm going to connect all on a terminal switch under the dash. The framing under the dash is not grounded at all, seem it should be. This car has added black wires in odd places, like going to the valve covers..
Links and any kind of answer is appreciated
Lee
Old Mar 3, 2026 | 08:13 PM
thoyer's Avatar
thoyer
Lee
The wire going to the valve cover is a factory wire. Grounds on a C1 are critical, make sure you get a good bond to the frame.
Do you have the AIM for your year? Wiring diagrams should be in there.
Doc Rebuild has good illustrated wiring diagrams https://shop.docrebuild.com/1961Corv...sGuideSet.aspx
Old Mar 4, 2026 | 01:28 PM
DZVette's Avatar
DZVette
Info on grounding points for our 1960 in the attached PDF. Likely similar for the '62.
Dave Z
Old Mar 4, 2026 | 02:53 PM
GVXCorvette
Thanks. Fantastic!
To Grounds
