[C1] Master cylinder
Old Apr 19, 2026 | 05:27 PM
DFH-GMC's Avatar
DFH-GMC
Default Master cylinder
1959 Can you bleed a master cylinder in the car. If not why?
Old Apr 19, 2026 | 05:30 PM
Limp's Avatar
Limp
My understanding is you cannot push the piston all the way in for bleeding as you can do with bench bleeding..
Old Apr 19, 2026 | 05:32 PM
DFH-GMC's Avatar
DFH-GMC
Thanks for the quick response
Old Apr 19, 2026 | 05:39 PM
R66's Avatar
R66
I have bled many master cylinders on the car. I prefer to bench bleed them, but if you do, do not push too hard on the spool as you can damage the rubber cups. If you bleed it on the car or on the bench, you still need to put a bleeding fitting on the outlet(s) to monitor the air movement.
I could be wrong, check your GM manual for directions.
Old Apr 19, 2026 | 05:44 PM
DFH-GMC's Avatar
DFH-GMC
I appreciate your advice
Old Apr 19, 2026 | 05:50 PM
DFH-GMC's Avatar
DFH-GMC
let me add some context.
I bled the master in the car, a bled all the wheels twice it just seems like the pedal is too low. It goes to the same spot every time and is a hard pedal. I’ve adjusted the brakes. They’re all dragging just to touch. Is there anything I can do to raise the pedal?
Old Apr 19, 2026 | 06:58 PM
R66's Avatar
R66
Is this a new master cylinder? Is it single cylinder or dual? How much play do have before the pedal starts to move the shoes? Is it possible the rod from the pedal to the master cylinder has not been adjusted with minimal play / clearance before moving the spool in the cylinder?
Old Apr 19, 2026 | 07:05 PM
Factoid's Avatar
Factoid
If you can pull the pedal up with your hand, then an adjustable pushrod will allow you to raise the pedal.
Old Apr 19, 2026 | 07:14 PM
DFH-GMC's Avatar
DFH-GMC
New master, it is 1/2” when the shoes touch and 3” till the pedal stops. That leaves the pedal 2” from the floor. I don’t think there’s any adjustment in the push rod.
Old Apr 19, 2026 | 07:48 PM
jforb's Avatar
jforb
Is it a single (original type) master cylinder? or a (modified) dual type master cylinder?
Singles bleed just fine in the car. Duals sometimes need to be removed and bench bled, especially since they never get enough cylinder travel, when replacing singles.
Old Apr 19, 2026 | 07:50 PM
DFH-GMC's Avatar
DFH-GMC
It is a single
Thanks Jim
Old Apr 19, 2026 | 08:36 PM
MelWff's Avatar
MelWff
How about raising the rear of the car enough so that the rear of the master is higher than front. Any air will go to rear and should bubble out when you step on the brake pedal.
Old Apr 20, 2026 | 08:42 AM
6D2148's Avatar
6D2148
If pedal is hard and goes to same level every time it’s not air in the system. Brake shoes are moving too far, broken or weak return springs, or needs full proper adjustment. What caused you to start this process, is master cylinder new/rebuilt?
Chip
Old Apr 20, 2026 | 10:09 AM
DFH-GMC's Avatar
DFH-GMC
Chip
The car has been sitting for over 40 years I replaced all brake parts with original type equipment except the drums I’m thinking it’s possible they may be oversized as in turned 1 too many times
Old Apr 20, 2026 | 10:48 AM
Limp's Avatar
Limp
Years ago, 75 ish, the mobile brake guy had oversized shoes he sold for oversized drums... I used them on my Jeep and saw many others used.. Never had a problem... Check around to see if these are available IF your drums are too big..
Old Apr 20, 2026 | 10:56 AM
DFH-GMC's Avatar
DFH-GMC
if my drums are too big, I will just replace them
Old Apr 20, 2026 | 10:59 AM
6D2148's Avatar
6D2148
Did you adjust to lock then back off or just to drag?
Chip
To Master cylinder
Old Apr 20, 2026 | 01:01 PM
DFH-GMC's Avatar
DFH-GMC
Chip
I adjusted to lock and backed off seven clicks
Old Apr 20, 2026 | 01:40 PM
6D2148's Avatar
6D2148
Well it’s worth a try to bleed mc on the car and see what happens, it won’t hurt anything.
Old Apr 20, 2026 | 02:26 PM
DFH-GMC's Avatar
DFH-GMC
I bled the master on the car I have a hard pedal it’s just too low I am going to have the drums measured I think they are oversized
