Engine Analyzer Software
Old May 13, 2003 | 01:54 PM
clearrun's Avatar
clearrun
Default Engine Analyzer Software
Who uses what? I want to evaluate various head / cam / carburetor / header combinations for myself. Any recommendations as to which software package to buy? I have a new computer with lots of capability - So that is not a limitation.
Old May 13, 2003 | 06:27 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Engine Analyzer Software (clearrun)
i have engine analyzer v3 from performance trends and it does not do a bad job comparing one setup to another. if you are looking for true HP outputs you will need a more expensive program but if you do not have air flows for the intake system the expensive one will not do much more. having the true air flow from a air flow bench is needed to get accurate results. :chevy
Old May 13, 2003 | 11:58 PM
Plasticman's Avatar
Plasticman
Default Re: Engine Analyzer Software (clem zahrobsky)
:iagree: Performance Trends. Also have the Desk Top Dyno 2.8, but the Performance trends is far more inclusive and accurate from what I have built and tested.
Plasticman
Old May 14, 2003 | 07:20 AM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Engine Analyzer Software (Plasticman)
I have dd dyno and also and an older version of perfromace trends engine analzyer 2.5,the ea25 program really helped me when i was building circle track motors .
Old May 14, 2003 | 08:04 AM
GregP's Avatar
GregP
I have Performance Trends Engine Analyzer 3.0 and Desktop Dyno 2000. For my motor combo at least they give the same results above 2500 RPM, some differences below that. DD 2000 is probably a little easier and user friendly (you will need to build the correct cam and head airflow files for your parts to get reasonable results), EA 3.0 has a few extra variables, such as more combinations of exhaust flow etc.
-Greg
Old May 14, 2003 | 05:33 PM
bcwaller's Avatar
bcwaller
C2 of Year Finalist (performance mods) 2019
Default Re: Engine Analyzer Software (GregP)
I've got Dyno2000 and it is easy, although is does not cover all the variables that well. Also, I have a $40 off offer if you order by the end of May. Let me know if you want to use it.
To Engine Analyzer Software
