Headliner
Old Jul 14, 2003 | 09:43 PM
JimSR's Avatar
JimSR
Default Headliner
Going to be putting in new headliner . Its mounted on plastic I have everything off window molding,halo been a long time since I removed the old one and being a senior person I have (brain Farts) . Question is were do I begin should I install some kind of heat barrier to roof, is the liner glued to roof, or does the molding hold.
THANKS JIM
Old Jul 14, 2003 | 10:17 PM
66BBCoupe's Avatar
66BBCoupe
2025 C3 ('68-'73) of the Year Winner - Unmodified
2023 C1 of the Year Winner - Modified
2021 C2 of the Year Winner - Unmodified
Default Re: Headliner (JimSR)
Jim
I have a 66 Coupe and am fortunate to have the original headliner in excellent overall condition but showing signs of typical sag of the vinyl from the padded paper backing. Rather then messing it up by trying to reglue it, I took it down and stored it. The headliner I replaced it with came from Ecklers and has the heavy plastic preformed backing to match the coupe roof shape. When comparing to the original, I noticed that the overall thickness was thinner - so I bought modern roof headliner foam - cut and glued it to the new headliner backing for an exact original thickness match - and placed it up in the roof - halo end first - and secured with all the mounting trim - no glue - it has been perfect for two years in the hottest of weather. I have a photo record of the whole process including detailed photos of both headliners. I am in Connecticut as well so would be happy to speak with you by phone of even help you put it in if the distance is not to far from you.
