Re: 62 - initial dwell setting? (waynec)
:iagree:
A "snug" .016" will get you right at about 29-30 degrees dwell. Once set and fired up, use a dwell meter to get the dwell into the 30-31 degree range.
Word of caution on dwell meters: I have bought various dwell meters from Checker and Autozone. Running them against my calibrated Sun machine, the meters have been off by 5 to 10 degrees. The worst meter I have tested was a Sears Craftsman analog multi-tester: The dwell was off by 12 to 15 degrees. I'm currently running a Sears Digital Multimeter, and this one is right on the money.
