Suffix code HH
Old Mar 30, 2004 | 11:37 PM
jobberone's Avatar
jobberone
jobberone
Default Suffix code HH
I get this as a 65 300 or 365 engine. Anyone know of this code on a 68 engine either 327 or 350? The block is 3914660 and the crank for this engine is 3911001 so it appears to be a 68 and not a 65 to me. My knowledge and data base is limited though.
Old Mar 31, 2004 | 02:33 AM
ghostrider20's Avatar
ghostrider20
Default Re: Suffix code HH (jobberone)
Quote
In 1965, the HH code applied to the 365 HP option W/O AC and manual trans.
Mark
Old Mar 31, 2004 | 04:02 AM
jobberone's Avatar
jobberone
jobberone
Default Re: Suffix code HH (ghostrider20)
That's what I get. Someone has a 68 for sale with an HH code. There seems to be occasional odd ball engines with non-conforming codes but I'm confused by the 68 numbers and a HH code.
Old Mar 31, 2004 | 05:35 AM
Denney's Avatar
Denney
"HH" was also used for the 1969 model year and it was a 350ci, 300hp, 4Bbl, TH400 application for passenger cars. By the way in addition to 1965 Corvette applications, the "HH" code was also used for 1966-67 Corvettes (327ci, 300hp, 4Bbl, a/c, manual trans). :thumbs: So, if the casting indicates a 1968 calendar year, it is likely the 350ci passenger car application. :cheers:
Old Mar 31, 2004 | 12:56 PM
JohnZ's Avatar
JohnZ
Default Re: Suffix code HH (Denney)
NCRS shows usage of the 4660 block in '68 as "unverified", and there was no "HH" suffix used in any '68 model year Chevrolet application. :thumbs:
Old Apr 4, 2004 | 10:25 PM
jobberone's Avatar
jobberone
jobberone
Default Re: Suffix code HH (JohnZ)
Thanks all. This is really a great forum.
Old Sep 7, 2023 | 11:30 PM
zcon97's Avatar
zcon97
3rd Gear
I just picked up the same block today all the date codes are correct for a 1968 327 and has the HH suffix. However, some sites list the casting as a 1969 350. I haven’t pulled the pan to check the crank yet.
Old Sep 7, 2023 | 11:45 PM
65GGvert's Avatar
65GGvert
If it was cast in 68 and is truly an HH engine code, it is from a 1969 350-300hp, automatic passenger car.
Old Sep 8, 2023 | 12:09 AM
zcon97's Avatar
zcon97
3rd Gear
I find a listing on https://www.mortec.com/castnum.htm that shows a 68 327.
Old Sep 8, 2023 | 12:11 AM
zcon97's Avatar
zcon97
3rd Gear
Casting 3914660
Old Sep 8, 2023 | 04:49 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Necro thread of 19 years. New thread please!
To Suffix code HH
