Electronic Ignition Conversion input
Old Jul 23, 2004 | 02:03 PM
hansenisu's Avatar
hansenisu
St. Jude Donor '10
Default Electronic Ignition Conversion input
I have a 65 with a 327/350hp w/air. Anyone have any thoughts about or experience with Lectric Limited's Breakerless SE electronic ignition conversion kit or conversions that are similar to theirs? Any pros or cons regarding reliability, etc.?
Old Jul 23, 2004 | 02:43 PM
1COOL60's Avatar
1COOL60
From: Emporia, pay no attention to that man behind the curtain, KS
Default Mallory Unilite
I can't speak for the Lectric Limited unit, but I did install a Mallory Unilite conversion on my NOM '60. I have been very pleased with it. This unit uses a light source/shutter wheel arrangement, as opposed to magnetic impulse. The unit is totally contained in the distributor. It is a straight forward installation, which can be done with the distributor installed in the engine. I took my distributor out to install; it was easier to do that way. The only problem I have had is one of the wires at the connector plug loosened enough to where the engine would not start. This may have been my fault in that I may not have fully inserted the wire in the first place. Other than that one problem, I have not had any trouble for the five-plus years it has been installed.
Old Jul 23, 2004 | 03:19 PM
JR's66coupe's Avatar
JR's66coupe
I installed the Crane XR-I in my 66 L79. Simply remove the points and install it - very simple installation. It also has an adjustable rev limiter.
Old Jul 23, 2004 | 04:21 PM
STING67RAY's Avatar
STING67RAY
i also have the mallory unilite in my 67 sm.blk.
no problems for three years. no points to adjust, nothing to wear out.
Old Jul 23, 2004 | 05:46 PM
firemist1's Avatar
firemist1
I put a Pertonix ignition system in my '67 with their high voltage coil and what a difference. Noticeable improvement in performance, starting, and idling with no problems. The car stays in tune and there is no maintenance. Plugs, cap & rotor change every 3 years or so, and that's it!
Old Jul 23, 2004 | 06:52 PM
LouieM's Avatar
LouieM
I just added Lectric Limited's system to my 67 327/350. The engine definitely has a more crisp feel. There are some advantages to this system, mainly related to the module not burning up under certain conditions, as listed at their web site:
http://www.lectriclimited.com/breakerless_se.htm
Old Jul 23, 2004 | 08:55 PM
Stick's Avatar
Stick
I've also had good luck with petronix.
Old Jul 23, 2004 | 10:02 PM
Viet Nam Vett's Avatar
Viet Nam Vett
2015 C2 of Year
St. Jude Donor '04-'05-'06-'07-'08-'09-'10, '14-'15
I Have the same Unit Crane XR-1 Solid State... No Freaken L.E.D.s More Reliable Then The Mallory Unilite..
That stupid design left me stranded on a Cold 14 Degree Winter night do to a burned out led emitter.
LED's do not function well in excessive heat or cold..!! Those of you who are useing the Mallory Unilite.....BEWARE....!!!! Your Failure Time Is Just around the Corner...
Old Jul 24, 2004 | 09:41 AM
1COOL60's Avatar
1COOL60
Default No failures here
I can't speak for very cold weather operation, but I have driven mine on 100+ degree days with no problems. My engine also ran hotter back then than it does now, so I can assure you that mine has passed the heat test!
Old Jul 25, 2004 | 11:06 AM
Viet Nam Vett
2015 C2 of Year
Passed the heat test.......?????.. Sorta like playing Russian Roulette
Turning an led off and on 10 Billion times or so every min or so in 100+ degrees heat or extream cold with voltage and current surges is not my idea of good engineering..
I'm not the only one who has experienced failure with this product. I know of several people I have met at car shows who have thrown this unit away and switched to the Crane XR-1 Solid state impluse unit because it has failed and left them High and dry.
Just make sure you carry a set of gold old relieable points and a rotor in your glove box.
Old Jul 26, 2004 | 07:58 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Default Xr1
I installed the Crane unit last fall right before I took it to track for first time. it worked fine other than the goofy rev limiter is a very poor design. I messed with it and messed with it and it was shutting me off at under 6500 rpm or so no matter where I put it.
Then I never got around to messing with it again for awhile and had it in there when I drove it to BG for the Cruise In last May. All of a sudden it wouldn't rev over 4800 rpm or so!! I ended up putting back my 7 year old set of points in the hotel parking lot and .....whammo...instant 7000 rpm again! Was a little embarrasing when I wanted to take folks for rides!
Otherwise it fired fine....but the rev limiter is a POS and you can find lots of folks to back that up. Crane has offered to replace it,not sure if I'd put it back in though!
Crane makes excellent cams......not sure about their electronics yet though.
JIM
Old Jul 27, 2004 | 02:52 PM
1COOL60's Avatar
1COOL60
[QUOTE=Viet Nam Vett]Passed the heat test.......?????QUOTE]
I'd say driving on 100+ degree days with the engine at 220+ is a hot environment. You don't think so?
Like I said before, the unit has been there for over 5 years now, driving 3K to 7K miles per year. No problems.
To Electronic Ignition Conversion input
