Caliper casting numbers
Old Aug 1, 2004 | 08:35 PM
67's's Avatar
67's
Default Caliper casting numbers
On the front calipers I have the numbers are very strange 38301/38473
and 38405/38154, and a small VB&P stamp, did they restamp all there calipers? Are theese first or second design, they are on a '66.
Thanks,
Tom
Old Aug 2, 2004 | 01:14 PM
JohnZ's Avatar
JohnZ
Those are VB&P tracking/warranty numbers, if they're stamped. First-design caliper casting numbers started with "546..", and second-design caliper casting numbers start with "545..". Doesn't make much difference, as the rebuilders automatically machine the piston guides out of first-design cores so the second-design pistons they use will work in any core they rebuild.
Old Aug 2, 2004 | 01:19 PM
67's's Avatar
67's
Thanks John, do you know do the machine off the casting numbers also, I can't seem to find them on the calipers.
Thanks,
Tom M
To Caliper casting numbers
