inner fender replacement
Old Nov 2, 2004 | 08:55 PM
revupL78's Avatar
revupL78
Default inner fender replacement
I would like to know if it is possible to replace right side inner fender skirt on my 65 without damaging exterior fender and paint.Mine is cracked where the radiator support bracket bolts to inner fender.Thanks Greg
Old Nov 2, 2004 | 10:52 PM
wombvette's Avatar
wombvette
It is possible, but it would be a bunch of trouble. First of all removing it from the fiberglass panels would be tricky. Sometimes they will come off OK, but you take a chance of damaging the outer surface. About the only fool proof way would be to cut away at it leaving a little flashing on the inside of the fenders and then carefully prying or grinding off the rest. I dont know about you, but I dont care much for climbing into that fender well and getting all of that fiberglass down the back of my neck.
Old Nov 3, 2004 | 06:49 AM
revupL78's Avatar
revupL78
well,so far cutting it out and getting real dirty seems to be my only option. Wish me luck.
To inner fender replacement
