sun Visor trick
Old Nov 8, 2004 | 01:37 PM
tdelph's Avatar
tdelph
Default sun Visor trick
I know this will sound very amature... but I tried to unscrew the screw that holds the tension on the sunvisor where the little rod goes through, and it has a goofy little back thingy that keeps the screw from un-screwing. is there a tool needed to take the old visors apart and replace the rod and screws?
Old Nov 8, 2004 | 01:50 PM
Ron Miller's Avatar
Ron Miller
There probably is, there's usually a tool for most everything!! However, I usually hold mine using the pointed end of a small pair of needle-nosed pliers, doesn't take much to hold it, and lots of times you can hold it well enough with only your finger!!
Old Nov 8, 2004 | 03:59 PM
tdelph's Avatar
tdelph
I'll try that again. Mine is really old and kind of rusted together and stripped...thats why it keeps falling down when I need it up and out of the way. The screw turns...it just wont back off of the tab thingy.
I'll spend more time next time and see if I can do it.
Old Nov 8, 2004 | 04:02 PM
PG-LT4's Avatar
PG-LT4
Corvette Central has them. They sell them as screw driver tip set and I think there are 4 different sizes in a set.
Old Nov 8, 2004 | 04:21 PM
tdelph's Avatar
tdelph
thanks, I knew there was a tool, there is always another tool I have to buy.
thanks again for the answer.
Old Nov 8, 2004 | 06:56 PM
Ron Miller's Avatar
Ron Miller
Don't have to buy it if you don't want to. Take an old screwdriver and file out the center so that the outer edges catch the slots in the special nuts on your sunvisor. Not that hard to do!!
Old Nov 8, 2004 | 07:37 PM
tdelph's Avatar
tdelph
That could work. I will find an old screw driver and start grinding.
thanks
Old Nov 8, 2004 | 08:22 PM
Vette-66's Avatar
Vette-66
Screwdriver trick worked for me
Chuck
To sun Visor trick
