"Born On Date"
Old Nov 15, 2004 | 04:33 PM
65nassau's Avatar
65nassau
Default "Born On Date"
You see this so much on TV about beer it reminds me......
How do you tell when your car came off the assembly line?
I've heard of people knowing this, but if you weren't there, how do you tell? Can you do it by the VIN# ????
Let's try mine ...VIN # 194675S123034
How would you tell the date by that, or is it even possible?
Old Nov 15, 2004 | 05:00 PM
waynec's Avatar
waynec
Here's a place to calculate/estimate it:
http://www.ncrswi.bizland.com/wi_ncrs/bdaycalc.htm
Old Nov 15, 2004 | 09:19 PM
mdz06vetter's Avatar
mdz06vetter
St. Jude Donor '05-'10-'11-'12-'13-'14-'15
65nassau - since your ride appears to be a 1965, the link Wayne gave you shows your baby's birthday to be AUGUST 24, 1964
Old Nov 15, 2004 | 09:53 PM
MidShark's Avatar
MidShark
The Corvette Birthday Book says July 26, 1965.
Dick
Old Nov 15, 2004 | 11:44 PM
Cruzmeisters's Avatar
Cruzmeisters
Dick
NCRS web site I use sez 7/26/65
Cruz
Old Nov 16, 2004 | 12:29 AM
glensgreen65's Avatar
glensgreen65
Using the ncrs site I received an april 15/65 build day. I assumed/guessed my car would be earlier. I'm glad to see the April 65 date though. I just finished a February build date L-79 long block. Could this be within the "numbers match" window? Here's hoping.
Old Nov 16, 2004 | 09:13 AM
65RDSTR's Avatar
65RDSTR
I think that's in the window with one eyebrow raised. My engine is 7 days older than my car.
Old Nov 16, 2004 | 09:21 AM
repruet's Avatar
repruet
The numbers matching criteria has to be no more than 6 months prior to the build date. The build date they use is the one provided by this web site http://www.ncrswi.bizland.com/wi_ncrs/bdaycalc.htm
Old Nov 16, 2004 | 09:24 AM
repruet's Avatar
repruet
July 26, 65 would be correct. Your supposed to put in the last 5 digits. The last 4 gives you the August date.
Old Nov 16, 2004 | 09:39 AM
mdz06vetter
you are correct! the damned site was squirrelly last nite when I entered the "last five of the VIN"! or else, I had "too many fingers of single malt!" (VBG)
Old Nov 16, 2004 | 09:47 AM
hoolies's Avatar
hoolies
Default dates
question,inside of door panels are dated march 17 1965,build site
on ncrs says may 16 1965.that is reasonable time frame right for
my 65 vert.
thanks
hoolies
Old Nov 16, 2004 | 11:14 AM
JohnZ's Avatar
JohnZ
Yup, that's fine.
Old Nov 16, 2004 | 12:18 PM
Tom/99's Avatar
Tom/99
Use the last 5 digits of your serial number, not the last 4 as per the instructions.
Using the last 5, I get 4/30/65 (correct)
using the last 4, I get 1/11/65 (incorrect)
Old Nov 16, 2004 | 03:24 PM
65nassau's Avatar
65nassau
Thanks for the info guys, I knew that info was out there somewhere!
Old Nov 16, 2004 | 07:41 PM
waynec's Avatar
waynec
Wow, what a spread of dates! 8/24... 1/11... 4/30... 7/26...
So what IS the correct estimated build date? I got July 26 '65 with the NCRS Wisconsin Chapter online tool, and my NCRS pocket guide puts it in that same timeframe (about a week before the end of July), so I'd say 7/26 is the best estimate.
Old Nov 17, 2004 | 12:45 PM
JohnZ's Avatar
JohnZ
7/26/65 IS the correct date for 65nassau; if you enter the VIN correctly (last five digits, as the instructions tell you), you'll get that date, and it matches with the NCRS "Birthday Book" as well.
To "Born On Date"
