A-Arm Flaps
Old Dec 24, 2004 | 08:08 PM
Vette-66's Avatar
Vette-66
Default A-Arm Flaps
How difficult is it to replace the A-Arm Flaps?
Pretty easy to remove, but how does one put staples in the replacements?
Can someone describe how to replace...
Also, what about these..
Thanks,
Chuck
Old Dec 24, 2004 | 10:39 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
Its best to have a helper. While they are holding it in position use a skinny pointed object and from inside the wheel well poke through the existing holes and through the flap. Put the staple in from the engine bay side and bend it over. Do the staples one at a time. That is don't poke all the holes at once. This worked for me.
Old Dec 24, 2004 | 11:31 PM
78Vette-SA's Avatar
78Vette-SA
Also, if the existing flaps are in any kind of shape, you can lay the old over the top of the new and poke threw the old holes. Then just push the staples threw. I then take a pair of plyers with a slit up the middle and bend the ends over.
Old Dec 25, 2004 | 06:37 AM
Chuck Gongloff's Avatar
Chuck Gongloff
I keep a bottle of "white out" in the garage. I put a small white dot on the A arm flap when I poke through. Makes it easier to locate when you're pushing the staple back through.
Also, the SS staples are a real PIA to use. TOUGH to bend. I try to use regular steel staples, as they get painted anyway. Chuck
Old Dec 25, 2004 | 06:41 PM
DZVette's Avatar
DZVette
Vette-66,
Here's some things that i have tried with some success. Have to agree with Chuck, the SS staples are darn hard to bend!
Good luck!
DZ
Old Dec 25, 2004 | 07:54 PM
Vette-66's Avatar
Vette-66
Thanks for all the pointers and to DZ for the pictures ( they helped a lot ), I understand how to change these now... just have to make a couple of tools first
Chuck
Old Dec 26, 2004 | 11:15 AM
RoadVettes's Avatar
RoadVettes
DZ,
Great instructional guide
Old Dec 26, 2004 | 11:17 AM
JohnZ's Avatar
JohnZ
The original staples weren't SS - don't know why the pre-bent repro staples are. I make my own from 14- or 16-ga. galvanized steel wire (hardware store item) - same as the originals, much easier to work with. Hint: When attaching the seals to the edge of the triangular splash shields, do the indented area FIRST, then the straight runs - MUCH easier.
Old Dec 27, 2004 | 12:05 AM
orono64's Avatar
orono64
Clean up the area, contact cement the new flap in place with black 3M in the tube just enough to keep it in place...when it's set, drill through the old holes with a small drill slightly smaller than the stapels, push in the staples one at a time, push a bucking bar or 3 pound hammer head on the inside (engine side) of the staple and tap the legs over with a smaller hammer.. it's good to have a helper but I've done it several times by myself.
To A-Arm Flaps
