Aftermarket GAUGES?
Old Apr 26, 2005 | 09:35 PM
DMONSVETTE's Avatar
DMONSVETTE
all I got was this:
http://earchitect.50megs.com/corvette/gauge.htm
HTH
Old Apr 27, 2005 | 04:56 PM
Xakk's Avatar
Xakk
Did you take the lens off of the speedo cluster?
Great instructional page, BTW.
Old Apr 27, 2005 | 10:27 PM
DMONSVETTE's Avatar
DMONSVETTE
Those gauges and instructions are not mine. I just found the info
on corvettefaq.
Old Apr 28, 2005 | 10:22 AM
fauxrs2's Avatar
fauxrs2
Yes the lens was removed - however since the frame around the cluster is actually part of teh lens assembly what I really did was cut the lens part out with a dremel (leaving the frame surround) and paint it black.
This is about as close up a shot as I ever took of that cluster.
Each gauge mounts through a piece of 1/4" plexiglass (a gap was left in the middle so that the original warning lamps would remain visible) this was glued and screwed over a gauge bezel I got from another forum member.
These bezels have included the buckets the old guages are protected by, they have to be partially removed to allow the Autometers to fit - so the backside looks really abused - once the plastic pieces were cut out and fit the whole thing was painted and prewired on the bench before being installed in the car.
Old Apr 28, 2005 | 05:01 PM
joes79's Avatar
joes79
St. Jude Donor '05
Default used oil pressure gauge
Hi, anyone replaced a working oil pressure gauge that would fit on my '79 coupe? I could use an original part. Thanks, Joe.
Old Apr 29, 2005 | 03:26 PM
79ls1's Avatar
79ls1
Yup, I have one. Drop me a note.
Fauxrs, Did you use the cut-off wheel to remove the lens or what? I've tried everything from a scroll saw to a burring tool, the plastic just melts back in behind the cut and it's hard to make clean.
Here's mine, but it's just a temporary layout. Autometer is coming out with the Cobalts in 5" for tach and speedo, so I'm changing it to that when they do. I want to do the panel more like the above using the original faceplate, maybe put the extra small gauges in a pod on the pillar or fab something behind the shifter.
http://img.photobucket.com/albums/v5...nelcloseup.jpg
http://img.photobucket.com/albums/v5...olecloseup.jpg
Old Apr 29, 2005 | 03:37 PM
70 LS1's Avatar
70 LS1
Originally Posted by 79ls1
Autometer is coming out with the Cobalts in 5" for tach and speedo...
Really? I talked with an Autometer representative a few weeks back and they had no plans on a 5" speedo and tach. What is the estimated release date?
Old Apr 29, 2005 | 03:41 PM
79ls1's Avatar
79ls1
Jeff,
I tried to drop you a message, didn't realize that you had a space between 70 and ls1, sorry.
Anyway, I E-mailed them last night, they replied this morning and said that it will be sometimes this fall and to contact them late this summer for a release date.
Old Apr 29, 2005 | 04:35 PM
fauxrs2's Avatar
fauxrs2
I have a clever little plexiglass cutter which is a simple hand held tool - it cuts it manually (no heat) - once it was cut i smoothed the cut with the dremel rotary sanding tool and small cutting wheels where needed - then polished the whole shmear with a small buffing wheel before painting.
A cutoff wheel would work but it would probably clog up abit because of heat. sneak up on it - dont try to cut it once, I cut back like an 1/8" or less from where i wanted it to be and then shaped my way to the finish location.
Old Apr 29, 2005 | 09:13 PM
rosslato's Avatar
rosslato
WOW, that looks great. nice job
Old Apr 29, 2005 | 10:11 PM
79ls1's Avatar
79ls1
Awesome job, man.
