Tailpipe restore??!!
Old Mar 30, 2005 | 09:48 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Default Tailpipe restore??!!
Noticed my chambered, aluminized, tailpipes are showing some surface rust. I know to clean them with wheel acid but, what, if anything, is out there to paint them with that won't look like Bubba painted them with $2.00 aluminum paint?
TIA
Old Mar 31, 2005 | 02:48 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Does no-one have opinion on this???
Old Mar 31, 2005 | 04:11 PM
Corvette69w427's Avatar
Corvette69w427
Depending on how bad the surface rust is, you can use steel wool or a Brillo pad to remove the rust making them shine again. I know this isnt much help as for a spray, but its the best I can do.
Old Mar 31, 2005 | 09:13 PM
sewright's Avatar
sewright
Oddly enough, I ran across this tonight from corvettefaq. Don't know if it will help but thought you might want to read it.
http://forums.corvetteforum.com/showthread.php?t=862847
Old Apr 1, 2005 | 11:51 AM
kdf1986's Avatar
kdf1986
Hello,
I have a similar problem with paint overspray on the left muffler. Rather than leave the paint on the muffler, I am planning on spray painting the muffler with a silver high temp paint. Something that will look close to the original appearence.
My opinion is I rather it look like it was painted than look like it had either overspray on it, or is begininning to rust out.
Sincerely
Bubba Gump.
Old Apr 1, 2005 | 01:23 PM
NHvette's Avatar
NHvette
I used POR20 on my entire system.
I guess it looks like a cheap paint job, but no rust.
It is clearly NOT the original aluminized coating.
http://NHvette.com/ftp/in/chassis_04.jpg
Old Apr 1, 2005 | 11:16 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
I'll check out the POR-20 - Looks Great!!!
Thanks to all for the input!!!!!!!!!
To Tailpipe restore??!!
