Ignition Shields
Old Apr 23, 2005 | 04:22 PM
phclub's Avatar
phclub
New England Events Coordinator
Default Ignition Shields
Anyone with these installed on a 70 vert. My spring project is some minor engine detailing and I am trying to figure out what the lower end of the left/right vertical ignition shield bolt to. On the left it appaears it could bolt to the lower spark plug bracket but the right side does not appear to have a hole through the bracket to bolt to.
Old Apr 23, 2005 | 07:55 PM
dennis's Avatar
dennis
Have all those of my 70 right now. If I follow,your right on the driver side. It wing nuts to the black bracket that seperates the plug wires.
On the right side it wing nuts to the chrome shield covering the back 2 spark plugs,(6 &8). Theres also a hole in the center of this piece that fits around the temp switch for the TCS wire to go through.
Old Apr 24, 2005 | 10:17 AM
phclub's Avatar
phclub
Just asking on the verticals that connect from the distibutor box. On the drivers side I see a hole to attach the chrome to the lower spark plug bracket but, on the passenger side the bracket is diffrent and I can't seem to see any hole to attached the lower end of the shield.
Old Apr 24, 2005 | 11:28 AM
dennis's Avatar
dennis
Guess I didn't explain it right. The right vertical shield lower hole attaches to the right rear spark plug shield. Thats the chrome piece that covers the 6 & 8 spark plugs. It has a hole at the rear that a captured nut slips over so you can put a wing nut on it. I'll go take a pic later and post it
Old Apr 24, 2005 | 12:39 PM
phclub's Avatar
phclub
Now I get it, thanks for the explaintion. I was thinking that I could mount these without the spark plug covers but I guess I will need to put the four piece spark plug set on as well .
Old Apr 24, 2005 | 12:46 PM
phclub's Avatar
phclub
I took a minute to check out your ride , it appears we share the likes of the Donnybrook color.
Old Apr 24, 2005 | 01:08 PM
dennis's Avatar
dennis
Checked yours out too. Everytime I see donnybrooke green, I'm more convinced to bring it back.
Already changed the 74 silver interior color back to saddle. Your green int. was my 2nd choice.
To Ignition Shields
