DIY Hooker sidepipe heatshields for ~$100
Old Apr 27, 2005 | 10:55 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Originally Posted by sidepipes79
How did you go about cutting the tube in half.
great job !! How did you cut it so clean over 36" length ?
Old Apr 28, 2005 | 06:55 AM
PatsLs1vette's Avatar
PatsLs1vette
I usually dont care for covers,but man they are sweet,you did an outstanding job on those.
Old Apr 28, 2005 | 09:38 AM
CGGorman's Avatar
CGGorman
To make the line straight and parallel to the tube centerline, I laid the tube on a flat table and then got my 4' level and set it next to the tube so that they touched. I used the level as a straight edge and marked a line with a Sharpie. I then marked off the opposite side at half the circumferenc, or 6.28" (for a 4" OD tube, circumference is 12.5664". Formula for calculating is 2x3.1415xradius) and used the level again as a simple straight edge.
Cutting was done with a pneumatic cut-off tool, by hand. It's not as perfect as it looks, but the cut edges aren't as visible as you'd think once the shield is mounted.
I would have rather cut it on my table saw, but it was burried under other unfinished projects and I didn't have a suitable blade. I've never had much luck getting a bandsaw to make cuts like this without the tube twisting (like a spiral) as I cut.
It's not as hard as it sounds...really!
Old Apr 28, 2005 | 10:33 PM
ICEMAN59's Avatar
ICEMAN59
I am a mechanical contractor by trade, I build Ice plants, chemical refrigeration packages, etc. from the frame up and I must say you did an execllent job on those.
Old Apr 30, 2005 | 10:40 AM
Buzzardz_vette's Avatar
Buzzardz_vette
Default Weld vs Bolts
I found something the works better than having to bolt on the brackets. It's called Ultrafuse and it can be used to repair/weld aluminum. No welding experience is needed, only a propane torch. Just heat the area you want to weld and apply the ultrafuse just like applying solder. Then you don't have to worry about drilling holes into the shield.
Old Apr 30, 2005 | 10:46 AM
Red73's Avatar
Red73
I'm not a big fan of shields on the Hooker side pipes. Those are the best looking ones that I've seen. Rod
Old Apr 30, 2005 | 10:53 AM
corvettecris's Avatar
corvettecris
ThaT isthe coolest DIY i have seen in a while! Looks awsome!
Old May 10, 2005 | 10:25 AM
CGGorman's Avatar
CGGorman
Got a chance to drive the car this weekend for the first time since I installed the shields. They get good-n-warm. Hot enough to let you know you're touching them, but not hot enough to blister...unless you react really slow. I'd say they maintain about 150 degrees.
Some time I may bend up new brackets with a .375" stand off instead of the .250". I don't think I'm getting enough air under the shields...
